Revit 3D View Camera Settings
ahmedabid933
3,184 次查看
14 条回复
1 条消息(共 15 条)
ahmedabid933
We are trying to replicate the view from Forge Viewer into a perspective view within Revit 2023.
To achieve this, we followed this article: Map Forge Viewer Camera back to Revit.
In Revit, when the internal origin is located at the center of the model, the views matched perfectly.
However, we have encountered an issue when the internal origin is not positioned at the center of the model. We couldn't find the same view.
This discrepancy in camera positioning appears to be the root of the problem.
If you have any insights or suggestions on resolving this issue, we would greatly appreciate your assistance.
0 个赞
3,185 次查看
14 条回复
回复 (14)
2 条消息(共 15 条)
jeremy_tammik
Maybe Eason can help you, being the author of the post you refer to, so I sent him a message informing him of your question here.
0 个赞
3 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
Could you elaborate on what "internal origin is not positioned at the center of the model" means? Is it in viewer or in Revit?
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
0 个赞
4 条消息(共 15 条)
ahmedabid933
Thanks for your reply.
In Revit, I am testing on a first model, where the Internal origin is at the center of the model as shown in the photo below:
This works fine.
On another model, I noticed that the model is a bit far from the Internal origin point, and there I don't have the same view as on Forge.
0 个赞
5 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
已接受的解答
Thank you for getting back to me. If I understand correctly, this issue happens when mapping APS/Forge viewer's camera back to Revit, right? But that should be irrelevant to Revit's internal origin but related to how we map points in the viewer's coordinate space to Revit's internal coordinate space.
If so, please try to re-map the position and target from viewer's coordinate space to Revit one by multiplying the transform we get from `model.getInverseModelToViewerTransform()` in the viewer.
const state = viewer.getState({ viewport: true });
const model = viewer.getAllModels()[0];
const invTransform = model.getInverseModelToViewerTransform();
const currentTarget = new THREE.Vector3().fromArray( state.viewport.target );
// {x: -14.770469665527344, y: 36.571967124938965, z: -1.212925910949707}
const currentPosition = new THREE.Vector3().fromArray( state.viewport.eye );
// {x: -14.870469093322754, y: 36.57156276702881, z: -1.212925910949707}
const originTarget = currentTarget.clone().applyMatrix4( invTransform );
// {x: -15.02436066552734, y: -8.984211875061035, z: 4.921260089050291}
const originPosition = currentPosition.clone().applyMatrix4( invTransform );
// {x: -15.12436009332275, y: -8.984616232971192, z: 4.921260089050291}
And then in Revit,
public void SyncCamera() {
  using(var trans = new Transaction(dbDocument, "Map viewer Camera")) {
    try {
      if (trans.Start() == TransactionStatus.Started) {
        var view3D = activeDbView as View3D;
        // By default, the 3D view uses a default orientation.
        // Change the orientation by creating and setting a ViewOrientation3D
        var position = new XYZ(-15.02436066552734, -8.984211875061035, 4.921260089050291); ///!<<< viewer camera's position or state.viewport.eye
        var target = new XYZ(12.322365033072593, -154.95122627204464, -37.64853761076602); ///!<<< viewer camera's target or state.viewport.target
        var up = new XYZ(0, 0, 1); ///!<<< viewer camera's up or state.viewport.up
        var fov = 90.68087674208; ///!<<< viewer state.viewport.fov
        var aspectRatio = 0.10000024532334; ///!<<< viewer state.viewport.aspectRatio
        var sightDir = target.Subtract(position).Normalize();
        var right = sightDir.CrossProduct(up);
        var adjustedUp = right.CrossProduct(sightDir);
        var orientation = new ViewOrientation3D(position, adjustedUp, sightDir);
        view3D.SetOrientation(orientation);
        var zoomCorners = this.CalculateZoomCorners(view3D, position, target, fov, aspectRatio);
        var uiView = activeUIDocument.GetOpenUIViews().FirstOrDefault(v => v.ViewId == view3D.Id);
        uiView.ZoomAndCenterRectangle(zoomCorners[0], zoomCorners[1]);
        activeUIDocument.RefreshActiveView();
        activeUIDocument.UpdateAllOpenViews();
        trans.Commit();
    } catch (Exception ex) {
      trans.RollBack();
      TaskDialog.Show("Revit", ex.Message);
private XYZ[] CalculateZoomCorners(View3D view, XYZ position, XYZ target, double fov, double aspectRatio) {
  var sightVec = position - target;
  var halfHeight = Math.Tan((fov / 2) * Math.PI / 180) * sightVec.GetLength();
  var halfWidth = halfHeight * aspectRatio;
  var upDirectionVec = sightVec.CrossProduct(view.RightDirection).Normalize() * halfHeight;
  var rightDirectionVecOnNearPlane = sightVec.CrossProduct(upDirectionVec).Normalize() * halfWidth;
  var diagonalVec = upDirectionVec.Add(rightDirectionVecOnNearPlane);
  var corner1 = target.Add(diagonalVec);
  var corner2 = target.Add(diagonalVec.Negate());
  return new XYZ[] {
    corner1,
    corner2
Cheers,
Eason Kang
Developer Advocate
6 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
已接受的解答
Hi @ahmedabid933,
I haven't had the luck to hear back from you yet. But I updated my sample here. Maybe you can try to see if it works for you.
https://github.com/yiskang/aps-viewer-revit-camera-sync
Cheers,
Eason Kang
Developer Advocate
7 条消息(共 15 条)
jeremy_tammik
已接受的解答
Eason explored further to resolve this and many other aspects and published his results in two blog posts:
The solution looks very exhaustive indeed. Thank you very much for that, Eason!
8 条消息(共 15 条)
ahmedabid933
Hi @eason.kangEDLV4 and @jeremy_tammik ,
I want to express my gratitude for your invaluable assistance and support.
I tried the solution and it worked fine. It's really exhaustive.
Thanks to your expertise and willingness to help, I was able to understand the problem and resolve it.
Thank you very much for your valuable assistance.
Best regards,
0 个赞
9 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
It's our great honor to help you with the topic. Thank you very much for your kind testing and good news!
I'm also glad to hear my sample and blog posts work for you. 🙂
Cheers,
Eason Kang
Developer Advocate
0 个赞
10 条消息(共 15 条)
igor.barcelosC54YD
Hi Eason, I hope you're doing well.
So I've implemented the full solution as you have documented here : https://github.com/yiskang/aps-viewer-revit-camera-sync
I could notice that there is still some differences between the Revit and Forge cameras, most precisly the distance to the borders.
in Revit :
In Forge :
Reading you tutorial, you've written :
 "As we mentioned in the previous blog post, please be aware that the camera parameters in APS Viewer and Revit are different, so the mapping results would not be perfectly matched."
Is that the case ?
0 个赞
11 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
Hi Igor,
Yes, it should be the case because the cameras in Revit and APS Viewer are different. We have only limited ways to control both cameras, so I put the disclaimer there.
Sorry for providing  imperfect solution.
Cheers,
Eason Kang
Developer Advocate
0 个赞
12 条消息(共 15 条)
igor.barcelosC54YD
I'm still facing some problems when mapping Revit camera's back to Forge. I'm in perspective mode.
The problem is that the zoom in Forge viewer is very different from Revit.
I know that there is no perfect solution but I got a felling that the results should not be that bad.
Revit :
Forge :
Any ideias  ?
0 个赞
13 条消息(共 15 条)
eason.kangEDLV4
Autodesk Support
Autodesk Support
Well ... It's hard to tell without examining the Revit model. It could be case by case. Please consider sharing a non-confidential test model. If your model contains personal or confidential information, please remove it before sharing.
If you're a paid ADN member, you can share the test model through the ADN portal (https://aps.autodesk.com/adn) by creating a support case.
Eason Kang
Developer Advocate
0 个赞
14 条消息(共 15 条)
igor.barcelosC54YD
Hi Eason,
Below you can find the Revit file that I've tested.
In Revit I have the following camera properties:
In Forge I found this :
As you can see the zoom in Forge is quite different from Revit's.
What could explain this behaviour ?
0 个赞
15 条消息(共 15 条)
Sleepingfish_Kuo
IsPerspective: False
When exporting a perspective 3D view in Revit, the camera position and direction are included.
However, when exporting an orthographic view, only the direction is retained, the model size and offset is gone.
0 个赞
