Hi everyone,
Is it possible to create a standard wall in Revit and then modify its profile so that the wall has different heights at its start and end points?
Context:
In my UI, the user specifies: a height at the start point of the wall, a different height at the end point of the wall. So the wall should not have a uniform top, but instead one side higher than the other (an inclined/trapezoidal geometry).
Goal:
I’m looking for a solution in the Revit API (2024, and if possible 2026) that allows generating this type of wall with variable heights.
Thanks in advance for your help!
