How to Create a Wall with Variable Start/End Heights via Revit API?
F_Bgdh
F_Bgdh
Hi everyone,
Is it possible to create a standard wall in Revit and then modify its profile so that the wall has different heights at its start and end points?
Context:
In my UI, the user specifies: a height at the start point of the wall, a different height at the end point of the wall. So the wall should not have a uniform top, but instead one side higher than the other (an inclined/trapezoidal geometry).
Goal:
I’m looking for a solution in the Revit API (2024, and if possible 2026) that allows generating this type of wall with variable heights.
Thanks in advance for your help!
Charles.Piro
with the Revit API you can create a wall with a specific profile. So, if you define all the points of your wall, you can create the curves between them and create a new wall.
Here is the documentation for creating a wall by profile : https://www.revitapidocs.com/2024/8d651eae-ae63-bc50-5f43-383d71ec4301.htm
PIRO Charles
Developer
PIRO CIE
Linkedin
Mohamed_Arshad
Hi @F_Bgdh
As @Charles.Piro  mentioned you need use the Create Method (Document, IList(Curve), ElementId, ElementId, Boolean) to create wall. I have additionally added the sample implementation of method for your reference.
Reference Code
 /// Units mm
 ///Create Profile
 ///              * P3
 /// P4 *         *
 /// P1 * * * * * * P2
 ///Points Creation
 XYZ p1 = XYZ.Zero;
 XYZ p2 = new XYZ(5000 / 304.8, p1.Y, p1.Z);
 XYZ p3 = new XYZ(p2.X, p1.Y, 10000 / 304.8);
 XYZ p4 = new XYZ(p1.X, p1.Y, 5000 / 304.8);
 List<Curve> profile = new List<Curve>()
     Line.CreateBound(p1,p2),
     Line.CreateBound(p2,p3),
     Line.CreateBound(p3,p4),
     Line.CreateBound(p1,p4)
 ///Get Default Wall type
 ElementId wallTypeId = new FilteredElementCollector(doc).OfClass(typeof(WallType)).FirstElementId();
 ///Get Level Id
 ElementId levelId=  new FilteredElementCollector(doc).OfClass(typeof(Level)).FirstElementId();
 ///Is Structural
 bool isStructural = false;
 using (Transaction createWall = new Transaction(doc,"Create Wall"))
     createWall.Start();
     Wall wall= Wall.Create(doc,profile,wallTypeId,levelId,isStructural);
     createWall.Commit();
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
F_Bgdh
Thank you so much, @Charles.Piro , for your help with your Revit API solution it really unblocked me 😁
F_Bgdh
Many thanks to @Mohamed_Arshad  for providing such a detailed and well-explained Revit API solution. Your guidance was invaluable and really helped me progress. 👏
