Cant get SQLite to work with in my plugin, Revit 2024
Gilles.Lagrilliere
Gilles.Lagrilliere
Hello Everyone,
I have an updater and I want to use SQLite as my database. But everytime try to test my code, I get this error: System.DllNotFoundException: 'Unable to load DLL 'e_sqlite3': The specified module could not be found. (Exception from HRESULT: 0x8007007E)'
I can't find this DLL anywhere.
I get the error on this line:  using (SQLiteConnection connection = new SQLiteConnection($"Data Source={dbPath};Version=3;"))
Here is my code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Data.SQLite;
namespace TestSqlite
    public class Updater : IUpdater
        private readonly Guid id = Guid.NewGuid();
        private readonly UpdaterId updaterId;
        private readonly string dbPath = @"C:\Users\GillesLagrilliere\OneDrive - Talenco BVBA\Desktop\test.db";
        public Updater(AddInId addInId)
            this.updaterId = new UpdaterId(addInId, id);
        public void Execute(UpdaterData data)
            TaskDialog.Show("TestSqlite", "Updater Executed");
            try
                    connection.Open();
                    string sql = "CREATE TABLE IF NOT EXISTS Test (Id INTEGER PRIMARY KEY, Name TEXT)";
                    using (SQLiteCommand command = new SQLiteCommand(sql, connection))
                        command.ExecuteNonQuery();
                    sql = "INSERT INTO Test (Name) VALUES ('Revit Updater Triggered')";
                    connection.Close();
            catch (Exception)
                throw;
Any help is welcome!
Gilles Lagrilliere
Charles.Piro
you can resolve this issue by installing the SQLite packages and copy the dll files to the addin folder.
To begin, install the packages :
Install-Package Microsoft.Data.Sqlite
Install-Package SQLitePCLRaw.bundle_e_sqlite3
Once your solution is compiled, the dependency assemblies will be located in your debug folder and you can copy them to your addin folder.
PIRO Charles
Developer
PIRO CIE
Linkedin
Gilles.Lagrilliere
Hi
I tried your solution but now I get this error:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Exception: Library e_sqlite3 not found
plat: win
suffix: DLL
possibilities (3):
1) C:\Program Files\Autodesk\Revit 2024\runtimes\win-x64\native\e_sqlite3.dll
2) C:\Program Files\Autodesk\Revit 2024\e_sqlite3.dll
3) C:/Program%20Files/Autodesk/Revit%202024/e_sqlite3.dll
win TryLoad: C:\Program Files\Autodesk\Revit 2024\runtimes\win-x64\native\e_sqlite3.dll
thrown: System.ComponentModel.Win32Exception (0x80004005): The specified module could not be found
at SQLitePCL.NativeLibrary.TryLoad(String name, Loader plat, Action`1 log, IntPtr& h)
win TryLoad: C:\Program Files\Autodesk\Revit 2024\e_sqlite3.dll
win TryLoad: C:/Program%20Files/Autodesk/Revit%202024/e_sqlite3.dll
NOT FOUND
at SQLitePCL.NativeLibrary.Load(String libraryName, Assembly assy, Int32 flags)
at SQLitePCL.Batteries_V2.MakeDynamic(String name, Int32 flags)
at SQLitePCL.Batteries_V2.DoDynamic_cdecl(String name, Int32 flags)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
at Microsoft.Data.Sqlite.SqliteConnection..cctor()
It still can't find e_sqlite3.dll.
Charles.Piro
sorry to hear that. I searched and found the e_sqlite3.dll file inside my C:/Microsoft Visual Studio folder. For me, the path is : C:\Program Files\Microsoft Visual Studio\2022\Community\Common7\IDE\Extensions\Microsoft\Copilot\Conversations.Service\runtimes\win-x64\native
but I'm not sure if it's the same for you. To help you, I've joined the assembly.
PIRO Charles
Developer
PIRO CIE
Linkedin
