Revit 2022 freezes on component selection . CefSharp.BrowserSubprocess.exe ???
T.Bannink4QQCM
T.Bannink4QQCM
Not sure if this is the right place for the question.
With the new image (Citrix VDI) we have the problem that revit 2022 freezes when we want to select a component the propertiesbar.
If we look at the processes with are actief there is one proces actief: CefSharp.BrowserSubprocess.exe
When we kill this proces Revit runs fine. If we kill al of them...Revit runs fine. So there is no need for the proces to exist from what I can see.
When we run Revit on a stand alone. It runs fine. With all (4) CefSharp.BrowserSubprocess.exe.
I found that this a generic/ much used proces. But is there a way to find out where the problem is being generated? Or has anyone had this problem also and knows what the problem is/might be?
Sincerely Tom Bannink
(work)System:
Citrix VDI
Win 10
Intel Xeon Gold 6226@2.70GHz (also on older systems)
memory: 20GB
Nvida Grid T$-2Q
stand alone (personal) System:
Win 10
intel 6700K @4.00GHz
memory: 64GB @Anonymous
2TB SSD
Nvidia GTX1080
jeremy_tammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, if you are not programming anything yourself using the Revit API, this is not the optimal place for this issue.
You cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
T.Bannink4QQCM
Wrong section. Sorry.
jeremy_tammik
No problem! Good luck solving it!
Was this problem resolved? I have the same problem and cannot find anywhere else that the question has been asked.
I would add 2 solutions to this:
Turn off any web browser when working in revit, Crome and "Edge" both did it to me OR even better turn off the addin "Revit 2022 BIM 360 Issues Addin" That fixed the issues for me!
