Weird Double value that suppose to be 0 but isn't
jaza008
jaza008
this happened after I set the Beam family's parameter; Start Level Offset and End Level Offset To any value that is not zero, then I change it to zero, and what happened is in the first picture.
Funny enough the value seems to be random.
jeremy_tammik
Yes. Well. This is due to the imprecision associated with real numbers in digital computers.
The 'weird' number that you see is not really weird at all.
It is just a very small number written in exponential or scientific notation.
Real numbers in computation:
https://en.wikipedia.org/wiki/Real_number#In_computation
Scientific notation:
https://en.wikipedia.org/wiki/Scientific_notation
Form your description, it was generated by adding an offset and subtracting it again. Both of the offsets were not represented precisely, e.g., because they were converted from metric to imperial units. The result was imprecise, almost exactly zero, but very slightly off.
That is completely normal and must be taken into account whenever dealing with real numbers of a digital computer, for instance, in many operations, e.g., comparisons,  by adding some fuzz:
