Revit 2019 - start error
rtservice_as
rtservice_as
Hi.
Every time when i try to start revit 2019 comming up error  - an unrecorebale error has occurred. The program will now be terminated.
What it kan be???
It's now problem with Revit 2017,2018 , Revit2019Viever - just with revit 2019
I using Win7 64bit
naveen.kumar.t
Autodesk Support
Autodesk Support
hi @rtservice_as ,
Check these links
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If the above links doesn't solve your problem then you need to post your question in appropriate forum because this forum is dedicated to REVIT API only
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @rtservice_as ,
check this one also
https://forums.autodesk.com/t5/revit-architecture-forum/an-unrecoverable-error-has-occurred-the-prog...
Naveen Kumar T
JimJia
Thank you for your query.
In general, we discuss pure Revit API related issues here in this forum.
You will probably obtain more fruitful answers on those issues in the Revit product discussion forum:
[https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133]
I hope this helps.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Email: Jim.Jia@autodesk.com
eric.zhang305
@rtservice_as
I hope all is well, when you got the error message, were you able to submit a crash report? If you can reproduce the crash, can you provide the email that was submitted with it?
If the comments above with the links helped, please accepted as a solution.
