sensor integration
sensor integration
opinarer
Observer Observer
sensor integration
opinarer
Observer
Observer
dear all,
how can I integrate the sensor information in a building model and manage the sensor data flow?
thanks
jeremytammik
Hi, and welcome to Revit API programming!
However, before you even start programming in the Revit API, I would strongly recommend the basics of manual Revit product usage through the end user interface.
Without Revit product understanding, you will not know what you are doing (or even what you wish to achieve) within the BIM context.
In the end user interface, you can implement a family for your sensors and use the family instances to represent individual items.
However, please do not discuss that here, since this forum is dedicated to programming, not to your need to develop your end user workflow first.
To get started with the Revit API, I suggest that you first of all take a look at the getting started material and work through the step-by-step instructions provided by the DevTV and My First Revit Plugin video tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will show you what other important material is available that you MUST be aware of, answer this question of yours, and many, many more besides.
Another quick way to get started: Please follow the instructions given in the hello world tutorials in the developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-93BC4416-FA94-44B3-AA66-931839DA44B4
For more information, please refer to the rest of the getting started material:
Good luck and have fun!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
