Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
refresh windows
2 REPLIES 2
Tripler123
1645 Views, 2 Replies
refresh windows
Hello everyone, I have two questions:
The first is that when I perform a command in revit (for example paint the pareder with the function override) the screen does not change. It is necessary to change click on the screen to be updated.
The second is that when using a winform I want to block it revit and can not access. That is to say only being able to work on the winform.
Tranks
2 REPLIES 2
pgerz
in reply to: Tripler123
1. try doc.Regenerate()
2. instead of form.Show() use form.ShowDialog()
Cheers
Peter
KManyrath
in reply to: pgerz
Would this work with grips that are not showing when you select an entity?
Forma Design Contest
Rail Community
