Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
refresh windows
2 REPLIES 2
Tripler123
1762 Views, 2 Replies
refresh windows
Tripler123
Hello everyone, I have two questions:
The first is that when I perform a command in revit (for example paint the pareder with the function override) the screen does not change. It is necessary to change click on the screen to be updated.
The second is that when using a winform I want to block it revit and can not access. That is to say only being able to work on the winform.
Tranks
refresh windows
Tranks
2 REPLIES 2
pgerz
in reply to: Tripler123
pgerz
1. try doc.Regenerate()
2. instead of form.Show() use form.ShowDialog()
Cheers
Peter
Cheers
Peter
KManyrath
in reply to: pgerz
KManyrath
Would this work with grips that are not showing when you select an entity?
