Problem with Addin-Manager
18627796338
18627796338
Hi, everyone! I'm just begin my study. When I created a small .dll file and add it into Revit 2015 through Addin-Manager, a message box came out.
But whether I choose yes or no, the addin file can run successfully. So is there any problem if I do not copy all the files to the temp folder? What's the differences between these two choices?
rosalesduquej
For first time test of the functionality of the API, my recommendation would be to go through the My First Revit Plugin Training.
In there you will find tips and workflows on how to use the Add-in Manager as well. Something I find strange with your dialog is the 51mb file size ? This makes me believe that you are adding all the Revit API dll to your dll, So again it is better if you go throug the lessons first to have better understanding on how the API works.
Here is the link : http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16777469
Cheers,
Happy coding.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Thank you very much! It really helps.
