Revit Build/Discipline Load Error
Dale.Bartlett
Dale.Bartlett
I have an addin that errors while loading on some computers only. The message is: "Revit cannot run the external application..." "Could not load file or assembly..."
My development version is:
Revit 2014 One Box - Build 20130308_1515(x64)
No Error:
Revit ARC - 20140709_2115(x64) UR3
Error:
Revit MEP - 20140709_2115(x64) UR3
My question is: Can the Revit Build and/or Discipline within one release (2014) cause an error?
.NET Framework (4.5) is another possibility which has been checked but not thoroughly. Mainly I am curious as to whether I should take into account the Build/Flavour.
Thanks again, Dale
______________
Yes, I'm Satoshi.
augusto.goncalves
If you're sending by email or downloading via web, it might be blocked
http://labs.blogs.com/its_alive_in_the_lab/2011/05/unblock-net.html
Also, indeed Revit 2014 is compatible with .NET 4.0, but it should run in compatibility mode.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
