- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear All,
How could I convert planerface.Normal to opposite direction.
Regards
Eden Oo
Dear All,
Regards
Eden Oo
Hi! Do you want to get the opposite direction? In such case just write -1*planerface.Normal or planerface.Normal.Negate(). But if you want to flip the face... it is not possible
Please always check your spelling. Otherwise, your thread might never be found by relevant later searches. This is about normals of planar faces represented by the PlanarFace class.
Here are some other threads relevant to this topic:
I believe that, together, they answer all possible questions on face normals and mesh triangle orientation.
Note the tricky bits in the third discussion, explaining why you need to differentiate between:
Many thanks to @Revitalizer and @FAIR59 for their analysis and illuminating explanations there!
Cheers,
Jeremy
