Modify Section and Callout
strsuraj
strsuraj
I am trying to modify the rectangular box - scopeBox of a section and also callout. Using the below code I was able to modify "Far Clip Offset" of Section. (marked in yellow)
Parameter vFarclip = currentView.get_Parameter(BuiltInParameter.VIEWER_BOUND_OFFSET_FAR);
                                    vFarclip.SetValueString("2500");
Please find the image.
But the other 2 edges Right side and Left side (marked in Red), I was not able to access.
Same for the callout.
Can anybody guide on how to access these properties for Callout and Section .
jeremytammik
The Building Coder has shared a whole bunch of discussions and samples on creating and setting up section views:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.38
They ought to cover all you need.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
strsuraj
Thanks @jeremytammik for pointing the right place.
I have done this change but couldn't really succeed.
currentView = viewElement as Autodesk.Revit.DB.View;
if (currentView.Name == viewName)
// my current sectionBox
BoundingBoxXYZ sectionBox= currentView.get_BoundingBox(currentView);
// updating max and min points for the current sectionBox sectionBox.Max = new XYZ(100,100,0); sectionBox.Min = new XYZ(0,0,0);
Transform oTrans = Transform.Identity; XYZ oMidPt = 0.5 * (sectionBox.Max + sectionBox.Min); oTrans.Origin = oMidPt; XYZ oDirZ = sectionBox.Transform.BasisZ; XYZ oDirX = sectionBox.Transform.BasisX; XYZ oDirY = sectionBox.Transform.BasisY; oTrans.BasisX = oDirX; oTrans.BasisY = oDirY; oTrans.BasisZ = oDirZ; sectionBox.Transform = oTrans;
Basically I am trying to update the max and min value of current section box and keeping the origin, Basis X Y and Z similar. And finally transforming the section box with these values. Is my approach wrong ?
Thanks.
