Hi.
In Revit SDK 2019. I am trying to recover the ID or name of the materials used in the walls of a project to then make budgets according to the price per square meter of the material and the area of the wall.
public void SetTypeParameter(Document doc) { Element e = FindElementByName(doc, typeof(Material), "SW48"); UIDocument uidoc = new UIDocument(doc); Reference myRef = uidoc.Selection.PickObject(ObjectType.Element, "Selecciona un elemento"); Element m = doc.GetElement(myRef); Wall pared = doc.GetElement(m.Id) as Wall; Material material = doc.GetElement(e.Id) as Material; double total; foreach (Parameter para in pared.Parameters) { TaskDialog.Show("revit", para.Definition.Name + " - " + para.AsValueString()); } try { using (Transaction t = new Transaction(doc, "Set Type")) { t.Start(); Parameter p = material.get_Parameter(BuiltInParameter.ALL_MODEL_COST); Parameter area = pared.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED); string MyString =area.AsValueString(); string NewString = MyString.Remove(2,3); total = ((p.AsDouble() * Convert.ToDouble(NewString))); p.Set(360); TaskDialog.Show("Precio", "Precio del material por m2: " + p.AsValueString()+"\n Area total del muro: "+area.AsValueString()+"\n Precio total: $"+total ); t.Commit(); } } catch (Exception ex) { TaskDialog.Show("error ", ex.Message); } }
In the code, I manually recover the cost of the "SW48" material. Is there a way that when selecting the wall I recover the material that is being used? Thank you.
Solved by naveen.kumar.t. Go to Solution.
Hi @Anonymous,
try the below code
Element e; IList<Material> MS = new List<Material>(); Wall w = e as Wall; if(w!=null) { IList<ElementId> mat_ids = w.GetMaterialIds(true) as IList<ElementId>; foreach(ElementId mat_id in mat_ids) { Material M = doc.GetElement(mat_id) as Material; MS.Add(M); } }
If you want the wall paint material to be excluded then
w.GetMaterialIds(false)
else if you want the wall paint material to be included then
