Material or texture associated with a wall.
Hi.
In Revit SDK 2019. I am trying to recover the ID or name of the materials used in the walls of a project to then make budgets according to the price per square meter of the material and the area of ​​the wall.
  public void SetTypeParameter(Document doc)
            Element e = FindElementByName(doc, typeof(Material), "SW48");
            UIDocument uidoc = new UIDocument(doc);
            Reference myRef = uidoc.Selection.PickObject(ObjectType.Element, "Selecciona un elemento");
            Element m = doc.GetElement(myRef);
            Wall pared = doc.GetElement(m.Id) as Wall;
            Material material = doc.GetElement(e.Id) as Material;
            double total;
            foreach (Parameter para in pared.Parameters)
                TaskDialog.Show("revit", para.Definition.Name + " - " + para.AsValueString());
            try
                using (Transaction t = new Transaction(doc, "Set Type"))
                    t.Start();
                    Parameter p = material.get_Parameter(BuiltInParameter.ALL_MODEL_COST);
                    Parameter area = pared.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED);
                    string MyString =area.AsValueString();
                    string NewString = MyString.Remove(2,3);
                    total = ((p.AsDouble() * Convert.ToDouble(NewString)));
                    p.Set(360);
                    TaskDialog.Show("Precio", "Precio del material por m2: " + p.AsValueString()+"\n Area total del muro: "+area.AsValueString()+"\n Precio total: $"+total );
                    t.Commit();
            catch (Exception ex)
                TaskDialog.Show("error ", ex.Message);
In the code, I manually recover the cost of the "SW48" material. Is there a way that when selecting the wall I recover the material that is being used? Thank you.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
try the below code
 Element e;
IList<Material> MS = new List<Material>();
                    Wall w = e as Wall;
                    if(w!=null)
                        IList<ElementId> mat_ids = w.GetMaterialIds(true) as IList<ElementId>;
                        foreach(ElementId mat_id in mat_ids)
                            Material M = doc.GetElement(mat_id) as Material;
                            MS.Add(M);
If you want the  wall paint material to be excluded then
w.GetMaterialIds(false)
else if you want the wall paint material to be included then
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Just what I needed. Thank you very much.
