Is there a way to resolve or skip over this failure:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Trying to delete a Reference plane that is probably owned by another user throws up a warning:
Now I am trying to resolve it with a Failure Handing as so:
public void FailureProcessing(object sender, FailuresProcessingEventArgs e) { var failureAccessor = e.GetFailuresAccessor(); var fmas = failureAccessor.GetFailureMessages(); if (fmas.Count == 0) { e.SetProcessingResult(FailureProcessingResult.Continue); } else { foreach (var fma in fmas) { if (failureAccessor.IsFailureResolutionPermitted(fma)) { failureAccessor.ResolveFailure(fma); } } e.SetProcessingResult(FailureProcessingResult.ProceedWithCommit); } }
Now that will basically request permission from the user and will display this dialog:
That's not ideal, since now I am stuck waiting for their reply.
Is there a way to just RollBack, skip over that element and move on with the remaining ones?
I tried this:
public void FailureProcessing(object sender, FailuresProcessingEventArgs e) { var failureAccessor = e.GetFailuresAccessor(); var fmas = failureAccessor.GetFailureMessages(); if (fmas.Count == 0) { e.SetProcessingResult(FailureProcessingResult.Continue); } else { foreach (var fma in fmas) { if (failureAccessor.IsFailureResolutionPermitted(fma)) { failureAccessor.RollBackPendingTransaction(); } } e.SetProcessingResult(FailureProcessingResult.ProceedWithRollBack); } }
That doesn't do anything. I just end up in the same spot with the warning bubbling back up to surface.
Here's my code:
[Transaction(TransactionMode.Manual)] public class DeleteReferencePlanes : IExternalCommand { public void FailureProcessing(object sender, FailuresProcessingEventArgs e) { var failureAccessor = e.GetFailuresAccessor(); var fmas = failureAccessor.GetFailureMessages(); if (fmas.Count == 0) { e.SetProcessingResult(FailureProcessingResult.Continue); } else { foreach (var fma in fmas) { if (failureAccessor.IsFailureResolutionPermitted(fma)) { failureAccessor.RollBackPendingTransaction(); } } e.SetProcessingResult(FailureProcessingResult.ProceedWithRollBack); } } public Result Execute( ExternalCommandData commandData, ref string message, ElementSet elements) { // Get application and document objects var uiApp = commandData.Application; var doc = uiApp.ActiveUIDocument.Document; uiApp.Application.FailuresProcessing += FailureProcessing; try { using (var trans = new Transaction(doc, "DeleteReferencePlanes")) { // Delete all unnamed Reference Planes in the project // Create Filter to check for Name var provider = new ParameterValueProvider(new ElementId(BuiltInParameter.DATUM_TEXT)); var evaluator = new FilterStringEquals(); var rule = new FilterStringRule(provider, evaluator, "", false); var filter = new ElementParameterFilter(rule); var refPlanes = new FilteredElementCollector(doc) .OfClass(typeof(ReferencePlane)) .WherePasses(filter) .Cast<ReferencePlane>() .ToList(); // display progress form var count = 0; var n = refPlanes.Count; var s = "{0} of " + n + " Reference Planes processed..."; const string pfCaption = "Delete Unnamed Reference Planes"; using (var pf = new ProgressForm(pfCaption, s, n)) { // delete all reference planes // do a final check for validity of objects trans.Start(); foreach (var plane in refPlanes) { if (WorksharingUtils.GetCheckoutStatus(doc, plane.Id) == CheckoutStatus.OwnedByOtherUser) continue; if (!plane.IsValidObject) continue; using (var subTrans = new SubTransaction(doc)) { subTrans.Start(); try { doc.Delete(plane.Id); count++; subTrans.Commit(); } catch (Exception) { subTrans.RollBack(); } pf.Increment(); } } trans.Commit(); } // show a dialog box with some basic stats TaskDialog.Show("Delete Reference Planes", "You have successfully deleted " + count + " unnamed reference planes!"); return Result.Succeeded; } } // Catch any Exceptions and display them. catch (Autodesk.Revit.Exceptions.OperationCanceledException) { return Result.Cancelled; } catch (Exception x) { message = x.Message; return Result.Failed; } } }
