creating detail lines
stanleypaseur
Message 1 of 9
stanleypaseur
I coming from VBA to C# and I am having trouble figuring out how to create detail lines. Can someone show me a few lines of code as to how to create a detail line. I am trying to write an application macro inside Revit. Your patience and help will be most appreciated.
Replies (8)
Message 2 of 9
IbrahimNaeem
Hi Stanley,
I don't know which Revit Version you use but I give here a piece of code I did, tested and works fine:
XYZ P1 = new XYZ(x1,y1,z1);
XYZ P2 = new XYZ(x2,y2,z2);
Line L1 = Line.CreateBound(P1,P2);
doc.Create.NewDetailCurve(vd,L1);
// where vd is the view you need to draw your detail lines in
// where doc is the active document
Hope this helps.
Thanks, Ibrahim Naeem
Message 3 of 9
Thank you it work well for me
Message 4 of 9
Hi  IbrahimNaeem.
 - Line line = Line.CreateBound(start, end);
 - DetailLine detailLine = (DetailLine) doc.Create.NewDetailCurve(view, line );
I try to Create 2D Detail Line from Pipe Slope but Can't create. Can you help me?
Thanks!
Message 5 of 9
IbrahimNaeem
Hi @Anonymous ,
a Z difference is not allowed for a detail line, simply set the z-value for each point to zero prior to creating the line.
start = new XYZ(start.X,strat.Y,0);
end = new XYZ(end.X,end.Y,0);
hope this helps.
Message 6 of 9
Hi @IbrahimNaeem.
Thank you it work well for me!
Message 7 of 9
landis.mark
How do I set a specific Line Style to my detail line as I create it?
Message 8 of 9
IbrahimNaeem
Hi@landis.mark , Here's a code sample on how to achieve this
//field definition
GraphicsStyle _gstyle;
internal static void setLineStyle(View vDraftingv, Line line, Document doc)
if (null == _gstyle || !_gstyle.IsValidObject)
var gstyles = (new FilteredElementCollector(doc)).OfClass(typeof(GraphicsStyle)).Cast<GraphicsStyle>().ToList();
_gstyle = gstyles.Where(x => x.GraphicsStyleType == GraphicsStyleType.Projection).FirstOrDefault(x => x.Name.ToLower() == "<wide lines>" /*or any name you wish to use*/);
 DetailCurve dc = doc.Create.NewDetailCurve(vDraftingv, line);
 if (_gstyle != null && _gstyle.IsValidObject) dc.LineStyle = _gstyle;
 Hope this helps.
Ibrahim Naeem
Message 9 of 9
landis.mark
Thanks, that was enough to figure out what I needed.
