Is there a way to resolve or skip over this failure:
sobon.konrad
sobon.konrad
Trying to delete a Reference plane that is probably owned by another user throws up a warning:
Now I am trying to resolve it with a Failure Handing as so:
        public void FailureProcessing(object sender, FailuresProcessingEventArgs e)
            var failureAccessor = e.GetFailuresAccessor();
            var fmas = failureAccessor.GetFailureMessages();
            if (fmas.Count == 0)
                e.SetProcessingResult(FailureProcessingResult.Continue);
            else
                foreach (var fma in fmas)
                    if (failureAccessor.IsFailureResolutionPermitted(fma))
                        failureAccessor.ResolveFailure(fma);
                e.SetProcessingResult(FailureProcessingResult.ProceedWithCommit);
Now that will basically request permission from the user and will display this dialog:
That's not ideal, since now I am stuck waiting for their reply.
Is there a way to just RollBack, skip over that element and move on with the remaining ones?
I tried this:
            else
                        failureAccessor.RollBackPendingTransaction();
                e.SetProcessingResult(FailureProcessingResult.ProceedWithRollBack);
That doesn't do anything. I just end up in the same spot with the warning bubbling back up to surface.
Here's my code:
[Transaction(TransactionMode.Manual)]
    public class DeleteReferencePlanes : IExternalCommand
            else
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            // Get application and document objects
            var uiApp = commandData.Application;
            var doc = uiApp.ActiveUIDocument.Document;
            uiApp.Application.FailuresProcessing += FailureProcessing;
            try
                using (var trans = new Transaction(doc, "DeleteReferencePlanes"))
                    // Delete all unnamed Reference Planes in the project
                    // Create Filter to check for Name
                    var provider = new ParameterValueProvider(new ElementId(BuiltInParameter.DATUM_TEXT));
                    var evaluator = new FilterStringEquals();
                    var rule = new FilterStringRule(provider, evaluator, "", false);
                    var filter = new ElementParameterFilter(rule);
                    var refPlanes = new FilteredElementCollector(doc)
                        .OfClass(typeof(ReferencePlane))
                        .WherePasses(filter)
                        .Cast<ReferencePlane>()
                        .ToList();
                    // display progress form
                    var count = 0;
                    var n = refPlanes.Count;
                    var s = "{0} of " + n + " Reference Planes processed...";
                    const string pfCaption = "Delete Unnamed Reference Planes";
                    using (var pf = new ProgressForm(pfCaption, s, n))
                        // delete all reference planes
                        // do a final check for validity of objects
                        trans.Start();
                        foreach (var plane in refPlanes)
                            if (WorksharingUtils.GetCheckoutStatus(doc, plane.Id) == CheckoutStatus.OwnedByOtherUser) continue;
                            if (!plane.IsValidObject) continue;
                            using (var subTrans = new SubTransaction(doc))
                                subTrans.Start();
                                try
                                    doc.Delete(plane.Id);
                                    count++;
                                    subTrans.Commit();
                                catch (Exception)
                                    subTrans.RollBack();
                                pf.Increment();
                        trans.Commit();
                    // show a dialog box with some basic stats
                    TaskDialog.Show("Delete Reference Planes", "You have successfully deleted " + count + " unnamed reference planes!");
                    return Result.Succeeded;
            // Catch any Exceptions and display them.
            catch (Autodesk.Revit.Exceptions.OperationCanceledException)
                return Result.Cancelled;
            catch (Exception x)
                message = x.Message;
                return Result.Failed;
I would be inclined to throw out all that FailureProcessing jazz. You are just deleting reference planes in one fell swoop. In my mind that is one transaction if any. That means putting the iterate refplanes - delete them try catch loop inside of an outer transaction. You would just bump over the error as it occurs without any rollback. Nothing needs to be rolled back. You could test the error type to keep track of what and how many refplanes were not deleted to bring that information outside for some sort of reporting. If these are ref planes your app is creating, then I would assume the user has ownership and the app could keep track of them by ID to be used later in a cleanup routine.
