Is it possible to get autocad block attribute from link CAD?
I use code from here .
I get original , geometry and rotation, but I can not get attribute.
jeremy_tammik
You should be able to determine this yourself using the element lister and RevitLookup:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
List all BIM elements, add the block, list the BIM elements again, determine the newly added objects, and explore them and their properties using RevitLookup.
jeremy_tammik
I stand corrected... I read the existing thread on getting to text objects within an imported DWG:
https://forums.autodesk.com/t5/revit-api-forum/get-to-text-objects-within-imported-dwg/m-p/5344375
It was pointed out by Matt in the thread on getting attributes from import CAD block:
https://forums.autodesk.com/t5/revit-api-forum/getting-attributes-from-import-cad-block/m-p/10179309
It explains that there is no direct access to text entities or attributes contained in the DWG file.
Workarounds:
  • Explode the DWG to create TextNote elements
  • Export the DWG to DXF and parse the resulting text file for the required data
  • Use the AutoCAD.NET API to read directly from the DWG
