Getting attributes from import CAD block
Hello people,
I came from this post:
https://forums.autodsk.com/t5/revit-api-forum/reading-cad-linked-object/td-p/7063811
Finally we are able to get blocks from an imported cad file into our model... now, I would like to get block attributes. Using the method GetInstanceGeometry I only can access to the "lines" that form a block, and not the attributes.
Anyone found something useful???
Thanks in advance!
matthew_taylor
Hi @Anonymous,
See this post:
https://forums.autodesk.com/t5/revit-api-forum/get-to-text-objects-within-imported-dwg/m-p/5344375#U...
It is being discussed at the moment. It refers to text, but I would imagine attributes are treated similarly.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Have you found a solution?
jeremy_tammik
Read the thread that Matt pointed out; it describes various workarounds.
