Offset Multiple
Offset Multiple
revitaddins
Message 1 of 8
Offset Multiple
revitaddins
Hi guys,
what's the best way to offset a line multiple times? I'm struggling to do it ;/
for(int i = 0; i < (numberOfOffset); i++ )
                        XYZ normal = XYZ.BasisZ;
                        Curve newLine = LongLine.CreateOffset(2000, normal);
                        doc.Create.NewDetailCurve(doc.ActiveView, newLine);
basically i need an array of lines
Thanks in advance.
Replies (7)
Message 2 of 8
jeremy_tammik
That looks perfectly fine to me.
Message 3 of 8
RPTHOMAS108
You are offsetting by 610m since internal units are ft.
Message 4 of 8
jeremy_tammik
Wow, very perceptive reading and guesswork!
Message 5 of 8
revitaddins
Thank you @RPTHOMAS108 ,
  double offset = UnitUtils.ConvertToInternalUnits(2000, DisplayUnitType.DUT_MILLIMETERS);
I converted it, but the problem is the lines stays in the same position
Message 6 of 8
RPTHOMAS108
I can't see from that what is wrong where is LongLine? Was you offsetting 2m from the adjacent wall (this looks about 2m judging from door)?
If you want cumulative offset for each iteration of your loop then you need to multiply distance by iteration or add it to running total each time (not just keep offsetting same distance from same line).
Thanks @jeremy_tammik as internal units are not metric I don't expect them to be rounded so nicely.
Message 7 of 8
revitaddins
Yes the offset will start from long line, and yes I guess that's what I need, cumulative distance, sorry for ignorance but that's where I'm failing, would you mind giving an example? Thanks
Message 8 of 8
RPTHOMAS108
It is also worth mentioning that your offset direction is going to be based on the direction of the line being offset. So for some instances you may have to either use (0,0,-1) rather than BasisZ or multiply offset value by -1 to get the direction of offset you want.
Dim Offset as Double = 304.8
For I = 1 to NumberOfOffsets
  Dim Total = I * Offset
  Dim NxtLine = LongLine.CreateOffset(Total, XYZ.BasisZ)
Next
or
Dim Total as double = 0
For I = 0 to NumberOfOffsets - 1
  Total += Offset
Next
