Revit export to dwg problems
Hello. I was working on a project, exported some sheets to .dwg everything seemed good. Now when I try to do exactly the same my exported sheet is incorrect. It has empty viewports and actual drawings in model space are rotated in a random direction with a random degree (or is it not random???).
Legends, tittle blocks, schedules, text exports correctly. Don't know what is wrong.
Please help, it's not the first time, it's getting annoying.
Adding some photos how it looks in revit and how it does export.
lucdoucet_msdl
Could you quickly clarify if you are exporting:
a. using the in program Revit commands from the menu or;
b. using the Application Programming Interface thru a dynamo or other scripting methode?
As you can see from the title of the forum you've posted to, this is the forum to get answers related to answer b.
You may get better results from the Revit Architecture Forum for general questions if your answer is a.
-luc
