Message 1 of 19
How to truly purge Project (Shared) Parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
To a project:
Add a Shared Parameter
Remove same Parameter
Save/Purge/Close Project
Edit Shared Parameter file to change name of same Parameter
Add changed Shared Parameter into same project
It will retain the original name as when it was first added.
I know the GUID is the defining ID, also the implications of the Parameter having been used elsewhere, also that the Shared parameter file is not designed to be edited manually. However, in my case I simply want all references to the original definition removed from my project file. I have tried many code snippets, and searched for hours with no success. Anyone?
______________
Yes, I'm Satoshi.
