Map shared parameter from one to another
I would like to create a single schedule that combines parameters from different categories. To give an example, I have an AHU (Mechanical Equipment) which contains multiple parameters. These parameters are shared parameters.
I need these same data also shown in HVAC Zone schedule. Is it anyhow possible to map the shared parameter from mechanical equipment to HVAC Zone. I only need to enter the input once into Mechanical Equipment.
Any help would be appreciated.
MERRY CHRSITMAS and HAPPY HOLIDAYS to you all.
A. Berk TORUN
jeremytammik
Dear A. Berk TORUN,
Thank you for your query.
Since the issue you describe has to do with end user product features and is not related to the Revit API, it is best addressed by an application engineer, product usage expert, or product support.
I am therefore passing it to product support for you.
Best regards and a Very Happy New Year to you!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Jeremy,
Thanks for your interest. I appreciate the connection. I'll be waiting for the reply from Support Team.
Regards.
