How to place a face base family at column and beam?
thannaingoo.api
thannaingoo.api
Dear Developer,
Is it possible to transform the face GetInstanceGeometry to GetSymbolGeometry?
I can use GetInstanceGeometry for intersection checking but I cannot use that face to place a family.
How should I place a family at intersection face of column and beam?
I want to check intersection at face  and then place a family.
Kindly help me.
Thanks Advance,
Naing Oo
List<Face> instanceFace = new List<Face>(); foreach (GeometryObject instObj in instance.GetInstanceGeometry()) { Solid solid = instObj as Solid; if (null == solid || 0 == solid.Faces.Size || 0 == solid.Edges.Size) { continue; } foreach (Face face in solid.Faces) { PlanarFace pf = face as PlanarFace; if (pf != null) { instanceFace.Add(pf); } } }
jeremytammik
Yes, that should be possible, by using the (possibly nested) sequence of geometry instance transform properties:
http://www.revitapidocs.com/2017/99cb4580-9b59-6564-8181-6082f275a869.htm
Some closely related aspects are discussed here:
http://thebuildingcoder.typepad.com/blog/2015/09/directshape-from-face-and-sketch-plane-reuse.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
thannaingoo.api
Thanks Jeremy,
How should I place a face base family to Column and Beam?
I can place a face base family to wall but I can't do for column and beam.
Is there any reference?
Naing Oo
aignatovich
Hi!
You can create faced base family instances on another family instance without any limits:
private static void CreateInstancesOnHostFamilyFaces(FamilySymbol familySymbol, FamilyInstance hostInstance)
	var faces = GetSolids(hostInstance)
		.SelectMany(x => x.Faces.OfType<PlanarFace>());
	var doc = familySymbol.Document;
	using (var transaction = new Transaction(doc, "create families"))
		transaction.Start();
		if (!familySymbol.IsActive)
			familySymbol.Activate();
		foreach (var planarFace in faces)
			var faceBox = planarFace.GetBoundingBox();
			var center = planarFace.Evaluate(0.5*(faceBox.Max + faceBox.Min));
			doc.Create.NewFamilyInstance(planarFace, center, XYZ.Zero, familySymbol);
		transaction.Commit();
private static IEnumerable<Solid> GetSolids(Element element)
	var geometry = element
	  .get_Geometry(new Options {ComputeReferences = true});
	if (geometry == null)
		return Enumerable.Empty<Solid>();
	return GetSolids(geometry)
		.Where(x => x.Volume > 0);
private static IEnumerable<Solid> GetSolids(IEnumerable<GeometryObject> geometryElement)
	foreach (var geometry in geometryElement)
		var solid = geometry as Solid;
		if (solid != null)
			yield return solid;
		var instance = geometry as GeometryInstance;
		if (instance != null)
			foreach (var instanceSolid in GetSolids(instance.GetInstanceGeometry()))
				yield return instanceSolid;
		var element = geometry as GeometryElement;
		if (element != null)
			foreach (var elementSolid in GetSolids(element))
				yield return elementSolid;
