Disable or enable updater
quocanhxd09
Message 1 of 8
quocanhxd09
Hi everyone,
I have just write code 1 IExternalApplication  “Updater” and then I run it successful. It will run when Revit start up .
I have 1 ask : after I run it, I want to create 1 IExternalCommand for disable “Updater” and 1 IExternalCommand for enable “Updater”.
I try to use method “DisableUpdater” but no successful.
Please help me how to create it.
Qa.
Thank you !
using System;
using System.Collections.Generic;
using System.Linq;
using System.Reflection;
using System.Windows.Forms;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Windows.Media.Imaging;
using View = Autodesk.Revit.DB.View;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.Attributes;
using Document = Autodesk.Revit.DB.Document;
namespace qa
    /// <inheritdoc />
    /// <remarks>
    /// This application's main class. The class must be Public.
    /// </remarks>
    public class UpdaterSommaire : IExternalApplication
        // Both OnStartup and OnShutdown must be implemented as public method
        public Result OnStartup(UIControlledApplication application)
            ElementId idparaPage = new ElementId(152713);
            ElementId idparaDate = new ElementId(152809);
            ElementId idparaDessine = new ElementId(334940);
            ElementId idparaPageName = new ElementId(335879);
            ElementId idparaIndice = new ElementId(335881);
            ElementId idparaVerifier = new ElementId(334942);
            // Register the ElementUpdater1
            ElementUpdater1 updater1 = new ElementUpdater1(application.ActiveAddInId);
            UpdaterRegistry.RegisterUpdater(updater1);
            ElementCategoryFilter catFilter = new ElementCategoryFilter(BuiltInCategory.OST_GenericAnnotation);
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaPage));
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaDate));
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaDessine));
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaPageName));
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaIndice));
            UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeParameter(idparaVerifier));
            return Result.Succeeded;
        public Result OnShutdown(UIControlledApplication application)
            // nothing to clean up in this simple case
            // Unregister the ElementUpdater1
            UpdaterRegistry.UnregisterUpdater(new ElementUpdater1(application.ActiveAddInId).GetUpdaterId());
    /// <remarks>
    /// The "HelloWorld" external command. The class must be Public.
    /// </remarks>
    [Transaction(TransactionMode.Manual)]
    public class DisableUpater : IExternalCommand
        public static bool enable;
        // The main Execute method (inherited from IExternalCommand) must be public
        public Result Execute(ExternalCommandData revit,
            ref string message, ElementSet elements)
            //ElementUpdater1 updater1 = new ElementUpdater1(revit.Application.ActiveAddInId);
            //UpdaterRegistry.DisableUpdater(updater1);
            //ElementUpdater1.m_updateActive = false;
            enable = false;
    public class EnableUpater : IExternalCommand
            //ElementUpdater1.m_updateActive = true;
            enable = true;
    public class ElementUpdater1 : IUpdater
        //public static bool m_updateActive = true;
        private AddInId mAddinId;
        private UpdaterId mUpdaterId;
        public ElementUpdater1(AddInId id)
            mAddinId = id;
            mUpdaterId = new UpdaterId(mAddinId, new Guid("B2059D9C-799A-48F1-9666-5AC54643D26E"));
        #region IUpdater Members
        public void Execute(UpdaterData data)
            Document doc = data.GetDocument();
            View activeView = doc.ActiveView;
            ICollection<Element> colGene = new FilteredElementCollector(doc, activeView.Id)
                .OfCategory(BuiltInCategory.OST_GenericAnnotation)
                .ToElements();
            string paramName = "Page";
            string paramIndice = "Indice";
            string paramDate = "Date";
            string paramDessine = "Dessine";
            string paramVerifie = "Verifie";
            HashSet<FamilyInstance> GenericTilte = new HashSet<FamilyInstance>();
            HashSet<FamilyInstance> lingSommaire = new HashSet<FamilyInstance>();
            foreach (Element element in colGene)
                FamilyInstance familyInstance = element as FamilyInstance;
                if (familyInstance == null) continue;
                if (familyInstance.Name.Contains("A3")) GenericTilte.Add(familyInstance);
                if (familyInstance.Name.Contains("Ligne de Sommaire")) lingSommaire.Add(familyInstance);
            foreach (Element ele in GenericTilte)
                string StringPage = ele.LookupParameter(paramName).AsString();
                string stringindice = ele.LookupParameter(paramIndice).AsString();
                string stringdate = ele.LookupParameter(paramDate).AsString();
                string stringdessine = ele.LookupParameter(paramDessine).AsString();
                string stringverifie = ele.LookupParameter(paramVerifie).AsString();
                string stringPagename = ele.LookupParameter("PageName").AsString();
                foreach (Element ele2 in lingSommaire)
                    if (ele2.LookupParameter("PageName").AsString() == stringPagename)
                        ele2.LookupParameter(paramName).Set(StringPage);
                        ele2.LookupParameter(paramIndice).Set(stringindice);
                        ele2.LookupParameter(paramDate).Set(stringdate);
                        ele2.LookupParameter(paramDessine).Set(stringdessine);
                        ele2.LookupParameter(paramVerifie).Set(stringverifie);
        public string GetAdditionalInformation()
            return "ElementUpdater1";
        public ChangePriority GetChangePriority()
            return ChangePriority.Annotations;
        public UpdaterId GetUpdaterId()
            return mUpdaterId;
        public string GetUpdaterName()
        #endregion
Replies (7)
Message 2 of 8
jeremytammik
Independently of your question:
Since you have stored
idparaPage
anyway, it would be much more safe and efficient to use that with GetParameter instead of LookupParameter to access the element parameters.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
jeremytammik
To disable the updater, you could simply return straight back from the Execute method if
m_updateActive
is false. That is what it was originally intended for, isn't it?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 4 of 8
quocanhxd09
thank you , @jeremytammik
That's good idea !
I can not  get value "m_updateActive" in other class. It always return value "null"
Can you mark in my code, @jeremytammik ?
Message 5 of 8
jeremytammik
Maybe it will help if you make it a static class variable.
And it will certainly help if you read up a bit on C# and .NET programming basics.
In this case, just search for 'access c# boolean variable from other class':
https://duckduckgo.com/?q=access+c%23+boolean+variable+from+other+class
Your question has nothing to do with the Revit API, it is very basic C# and .NET beginner stuff.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 8
quocanhxd09
yes, you're right. I am not programmer, and I have no experience in C# or Revit API.
I will try repair my code.
Thanks you so much ! @jeremytammik
Have a nice day !!!
Message 7 of 8
MarryTookMyCoffe
some time ago I made my registration of ElementUpdater the way that it will had a different icon while it is registered or not.
ofc you don't have to play in changing button icon
            String tabName = "your tab name";
            String ribbonPanelName = "Test";
            String buttonName = "Test Button";
            List<RibbonPanel> ribbonPanels = uiapp.GetRibbonPanels(tabName);
            RibbonPanel ribbonPanel = null;
            if (ribbonPanels.Exists(e => e.Name == ribbonPanelName))
                ribbonPanel = ribbonPanels.Find(e => e.Name == ribbonPanelName);
            if (ribbonPanel != null)
                ElementUpdater updater1 = new ElementUpdater(uiapp.ActiveAddInId);
                foreach (RibbonItem ribbonItem in ribbonPanel.GetItems())
                    if (ribbonItem.ItemType == RibbonItemType.PushButton)
                        if (ribbonItem.Name == $"{ buttonName }")
                            if (UpdaterRegistry.IsUpdaterRegistered(updater1.GetUpdaterId()))
                                UpdaterRegistry.UnregisterUpdater(updater1.GetUpdaterId());
                                (ribbonItem as PushButton).LargeImage = App.BitmapToBitmapImage(Resources.Off);
                            else
                                ElementCategoryFilter catFilter = new ElementCategoryFilter(Autodesk.Revit.DB.BuiltInCategory.OST_PipeCurves);
                                UpdaterRegistry.AddTrigger(updater1.GetUpdaterId(), catFilter, Element.GetChangeTypeElementAddition());
                                (ribbonItem as PushButton).LargeImage = App.BitmapToBitmapImage(Resources.On);
ElementUpdater class I used:
    public class ElementUpdater : IUpdater
        public ElementUpdater(AddInId id)
            mAddinId = id;
            mUpdaterId = new UpdaterId(mAddinId, new Guid("8a5b141a-cd9e-4c12-9f99-168c3ddb1de2"));
            //code
            return "ElementUpdater";
            return Autodesk.Revit.DB.ChangePriority.MEPSystems;
            return mUpdaterId;
        #endregion
remember to change guid.
do not worry it only gonna take Autodesk 5 years to fix bug
Message 8 of 8
quocanhxd09
Hi MarryTookMyCoffe,
Thanks for your answer.
I will try with your idea.
qa.
