How to load link from BIM360
IliaIvanov
IliaIvanov
Hello, My app allows to manage opening Revit Links Worksets, but it works only with links from local path or server, so I would like to use this app for Links from BIM360, anyway I can`t use RevitLinkType.LoadFrom method, Is there anybody solve this problem?
jeremytammik
Dear Ilia,
Thank you for your query and for raising it here in the public discussion forum.
I think you should be using the Forge BIM360 REST API to access models on BIM360:
https://forge.autodesk.com/developer/documentation
Here is a tutorial showing how to download files from BIM 360 document management:
https://forge.autodesk.com/en/docs/bim360/v1/tutorials/documen-management/download-document
This question and similar related issues have been discussed previously here in the forum.
One of the more extensive threads presents a couple of suggestions:
https://forums.autodesk.com/t5/revit-api-forum/browsing-model-files-in-the-cloud-a360-c4r/m-p/843279...
In it, Ali Talebi says:
This can be used to open C4R models directly via the Revit API where it was not possible via Forge. I think the Forge API can already help with the BIM360 part.
I hope this helps.
Meanwhile I have asked the development team whether they have any more up-to-date suggestions for you.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jeremytammik
Dear Ilia,
I heard back from the development team, who say:
If it's a Desktop Connector link, then they should be able to use LoadFrom or Create with the local-path-on-disk that the link downloads to, and Revit will interpret it as a BIM360 link.
For a Revit Cloud Worksharing link: right now there is no API to link cloud model or workshared cloud model. We have a user story about this in our backlog.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
IliaIvanov
Dear Jeremy,
Thanks a lot!
I think it can help me.
IliaIvanov
Dear Jeremy,
Thanks a lot! I think it can help me.
mohamed_youssefD37ZM
Dear Jeremy
Thanks for this replay , and in 2023 are there any update regarding link the cloud models from BIM360 or ACC
