How to export pipe using CustomExporter?
techXMKH9
techXMKH9
I am a simple pipe in my Model and I am using CustomExporter to export the model into obj format.
But OnPolymesh is never triggered.
How can I export the pipe's geometry and material?
jeremytammik
This other post today reports a different problem, and proves that there is no problem of the kind you describe exporting pipe geometry:
https://forums.autodesk.com/t5/revit-api-forum/pipes-geometry-through-exportcontext/td-p/9071902
Are you sure you are running your custom exporter in a view that is set up to display pipes at all?
You may be running into a trivial issue with your view settings.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
techXMKH9
I do not know what I'm doing wrong.
      CustomExporter expr_DA = new CustomExporter(document, new SentioExporter());
            expr_DA.IncludeGeometricObjects = false;
            expr_DA.ShouldStopOnError = false;
#if DEBUG2019 || RELEASE2019
            View3D view3D = Utils.Find3DView(document, "3D View 1");
            expr_DA.Export(view3D);
#endif
using Autodesk.Revit.DB;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace Solutionario.Sentio
    class SentioExporter : IExportContext
        public void Finish()
        public bool IsCanceled()
            return false;
        public RenderNodeAction OnElementBegin(ElementId elementId)
            return RenderNodeAction.Proceed;
        public void OnElementEnd(ElementId elementId)
        public RenderNodeAction OnFaceBegin(FaceNode node)
        public void OnFaceEnd(FaceNode node)
        public RenderNodeAction OnInstanceBegin(InstanceNode node)
        public void OnInstanceEnd(InstanceNode node)
        public void OnLight(LightNode node)
        public RenderNodeAction OnLinkBegin(LinkNode node)
        public void OnLinkEnd(LinkNode node)
        public void OnMaterial(MaterialNode node)
        public void OnPolymesh(PolymeshTopology node)
        public void OnRPC(RPCNode node)
        public RenderNodeAction OnViewBegin(ViewNode node)
        public void OnViewEnd(ElementId elementId)
        public bool Start()
            return true;
I've attached the model also. It has a view named "3D View 1".
techXMKH9
Since I am new to Revit, I didn't know that view's leveldetail has to be set to FINE to export pipe.
I hope it will help somebody save time.
jeremytammik
Congratulations on solving this and thank you for letting us know!
Jeremy Tammik
The Building Coder
