Pipes geometry through ExportContext
ebarMLN7G
ebarMLN7G
We are running into a bit of an issue with geometry that we are getting for pipes. It appears that perfect cylindrical pipes are exported in 4 quarters instead of one section (Attached images). Is there a way to change this behavior? If not, is there any explanation on why the geometry is being delivered like this?
Screen Shot 2019-10-04 at 7.19.45 PM.pngScreen Shot 2019-10-07 at 12.24.45 PM.png
jeremytammik
Yes. For some reason not quite clear to me, Revit often prefers to represent a circle by two half-circle arcs. Similar behaviour is probably present in cylinders as well, and hence in pipes also.
I can imagine that this is difficult or even more probably impossible to change.
Have tried controlling the quality of the geometry on custom export?
https://thebuildingcoder.typepad.com/blog/2016/02/reorg-fomt-devcon-ted-qr-custom-exporter-quality.h...
Jeremy Tammik
Developer Technical Services
The Building Coder
