Modify RibbonButton Large Image size
orosztamas
orosztamas
Hello Everyone,
I'm trying to have a wider than 32 image as a
RibbonButton.LargeImage
My button is set to about 100 width via a long name. The Revit API documentation describes the following:
What I experienced, that it has scaled my image to a width of 32, resulting it to be way smaller than my actual ribbon button, which behavour seems to be conflicting with the description.
Is there a solution for this?
jeremytammik
Nothing that I am aware of. The Revit API does not support this, afaik. You may possibly be able to use the .NET Windows.Forms and Automation libraries to achieve what you require.
Jeremy Tammik
Developer Technical Services
The Building Coder
