I have some fittings(pipe/duct) from linked files and want to extract the solid with some offset. As I have done some research for offset then only found the offset curves method. I have tried to offset the face also but the resultant geometry is wrong. I want a valid method that will create offset geometry for solids directly. Please let me know if we have anything in the API that will fulfill my requirements.
Nope, sorry, I am not aware of any such functionality in the Revit API. I suggest you make use of some additional geometry library that provides what you need. Please let us know what solution you end up with. Thank you!
OpenCascade? Cf.,
Thank you so much Jeremy for your reply.
I am working on this requirement to find any workaround/library, If I find something will share it here.
