browser organization grouping
a.noya
a.noya
Hello fellow C#ers,
I'm trying to create a viewlist and grouping them in the way of the active browserorganization.
In our template at the office we have multiple parameters called: prject_browser_level1, prject_browser_level2 etc.
The paramters are used in the browser organization under the tab "grouping and sorting" (see attachment).
Unfortunelately, i can't find them when going through all paramters within here:
BrowserOrganization.GetCurrentBrowserOrganizationForViews(commanddata.Application.ActiveUIDocument.Document).Parameters
Another way to do it is maybe within the information of a specific view.
Now i use the following code, and it's working for projects that use the browser organization called "all".
view.GetTypeId()) as ElementType
If there would be something like view.GetBrowserOrganizationGroup() i would be able to do it.
Does anyone has experience with this?
FAIR59
You can check if a View is visible in the ProjectBrowser:
BrowserOrganization org = BrowserOrganization.GetCurrentBrowserOrganizationForViews(doc);
bool viewIsVisible = org.AreFiltersSatisfied(myView.Id);
the "groupHeaders" for the view are :
List<FolderItemInfo> folderfields = org.GetFolderItems(myView.Id).ToList();
foreach( FolderItemInfo info in folderfields)
	// "groupheader" in browser == parameter value for grouping parameter
	string groupheader = info.Name;
	// parameterId for the grouping parameter
	// parameterId <0  parameter is BuiltInParameter
	ElementId parameterId = info.ElementId;
a.noya
Thank you very much,
That was exactly what is was looking for.
It works perfectly!
Rockit_for_Revit
I'm trying to do the same but I would like to get the very next or previous view in the project browser order. Any ideas?
mj.deboer
is it also posible to modify/create the browserorganization?
