Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to create offset solid geometry for fittings (pipe/duct fitting)
3 REPLIES 3
vidya.zende
208 Views, 3 Replies
I have some fittings(pipe/duct) from linked files and want to extract the solid with some offset. As I have done some research for offset then only found the offset curves method.  I have tried to offset the face also but the resultant geometry is wrong. I want a valid method that will create offset geometry for solids directly. Please let me know if we have anything in the API that will fulfill my requirements.
3 REPLIES 3
jeremy_tammik
in reply to: vidya.zende
Nope, sorry, I am not aware of any such functionality in the Revit API. I suggest you make use of some additional geometry library that provides what you need. Please let us know what solution you end up with. Thank you!
jeremy_tammik
vidya.zende
in reply to: jeremy_tammik
Thank you so much Jeremy for your reply.
I am working on this requirement to find any workaround/library, If I find something will share it here.
Rail Community
