Announcements
Hiding bubble by the closest line
diogo.vieiraBCKUL
diogo.vieiraBCKUL
I need to hide a bubble by the selected close line. But how is it possible to do? I know that DatumEnds.End0 can actually help with that. But how do I connect the selected line to the bubble side?
A- Selected line of the user
B- Bubble that is suppose to get hidden
RPTHOMAS108
There are multiple ways, two that I can think of:
1) If you create a Transform with Basis.X aligned with line direction, Z remains as Z (for plans) and Y is cross product of Z and X then you can use Tranform.OfPoint on each grid end. For example shown one resulting Y ord will be positive and one negative but the smallest absolute value will point to the nearest end.
2) Curve.Intersect(Curve, IntersectionResultArray) will give you an intersection result. This contains the intersection parameter on each curve (how near to one end or other). You also get XYZPoint which you can use XYZ.DistanceTo(XYZ) to find which end of grid is nearest.
diogo.vieiraBCKUL
I ended up finding an answer, in case, someone ever needs, here is the link: https://forums.autodesk.com/t5/revit-api-forum/how-to-know-true-datumends-end0-is-left-or-right-in-v...
diogo.vieiraBCKUL
Your second option looks lowkey helpful, will give it a try.
diogo.vieiraBCKUL
If everyone ever needs, here is the code:
try
				IList < Reference > rList =   PickDesiredGrids ( uidoc )  ;
				Reference reference =   PickLine ( uidoc )  ;
				var refPlane = doc . GetElement ( reference . ElementId )   as ReferencePlane ;
				XYZ sp = refPlane . BubbleEnd ;
				XYZ ep = refPlane . FreeEnd ;
				Curve c = Line . CreateBound ( sp , ep )  ;
				foreach   (  var item in rList )
					using   ( Transaction trans =   new   Transaction  ( doc ,   "Hide Bubble"  )  )
						trans . Start (  )  ;
						Grid grid = doc . GetElement ( item . ElementId )   as Grid ;
						Curve gridLine = grid . Curve ;
						XYZ spg = gridLine . GetEndPoint (  0  )  ;
						XYZ epg = gridLine . GetEndPoint (  1  )  ;
						SetComparisonResult scr = gridLine . Intersect ( c ,   out IntersectionResultArray intersectionResultArray )  ;
						XYZ point = intersectionResultArray . get_Item (  0  )  . XYZPoint ;
						if   ( spg . DistanceTo ( point )   > epg . DistanceTo ( point )  )
							grid . HideBubbleInView ( DatumEnds . End0 , doc . ActiveView )  ;
						else
							grid . HideBubbleInView ( DatumEnds . End1 , doc . ActiveView )  ;
						trans . Commit (  )  ;
			catch   ( Exception e )
				TaskDialog . Show (  "o"  , e . Message )  ;
Thanks a lot to  @RPTHOMAS108 for giving me some ideas to start doing it!
