How to know true DatumEnds.End0 is left or right in view?
Grid.Curve.GetEndPoint(0) does not return the same "End" with DatumEnds.End0 in view.
Therefore, how to define DatumEnds.End0 is on the left or on the right in view?
Here is my code and it not work correctly.
public class GridBubble : IExternalCommand
//get command
public bool bubbleTop = false;
public bool bubbleBottom = false;
public bool bubbleLeft = false;
public bool bubbleRight = false;
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
//all grids
var grids = new FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Grids).WhereElementIsNotElementType().ToList();
// Modify document within a transaction
using (Transaction tx = new Transaction(doc))
tx.Start("Grid Bubble");
#region gridsX and gridsY
var gridsX = new List<Grid>();
var gridsY = new List<Grid>();
foreach (Grid grid in grids)
var gridCurve = grid.Curve;
var gridDirect = gridCurve.GetEndPoint(1) - gridCurve.GetEndPoint(0);
if (Math.Abs(gridDirect.X).S_IsGreater(Math.Abs(gridDirect.Y)))
gridsX.Add(grid);
else
gridsY.Add(grid);
#endregion
//show form to get command
var checkBubbleForm = new SettingGridBubbleForm(this);
checkBubbleForm.ShowDialog();
foreach (Grid grid in gridsX)
//gridcurve
//check direction
var gridDirection = gridCurve.GetEndPoint(1) - gridCurve.GetEndPoint(0);
if (gridDirection.X < 0)
var auxBubbleLeft = bubbleLeft;
bubbleLeft = bubbleRight;
bubbleRight = auxBubbleLeft;
//left bubble
if (bubbleLeft)
grid.ShowBubbleInView(DatumEnds.End0, doc.ActiveView);
else
grid.HideBubbleInView(DatumEnds.End0, doc.ActiveView);
//right bubble
if (bubbleRight)
grid.ShowBubbleInView(DatumEnds.End1, doc.ActiveView);
else
grid.HideBubbleInView(DatumEnds.End1, doc.ActiveView);
tx.Commit();
return Result.Succeeded;
RPTHOMAS108
Try transforming into coordinate space of view and the comparing XY vals.
public Result TObj73(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
	if (commandData.Application.ActiveUIDocument == null)
		return Result.Cancelled;
	UIDocument UIDoc = commandData.Application.ActiveUIDocument;
	Document Doc = UIDoc.Document;
	ViewPlan AcView = UIDoc.ActiveGraphicalView as ViewPlan;
	if (AcView == null)
	Transform Tx = Transform.Identity;
	Tx.BasisX = AcView.RightDirection;
	Tx.BasisY = AcView.UpDirection;
	Tx.BasisZ = XYZ.BasisZ;
	FilteredElementCollector FEC = new FilteredElementCollector(Doc, AcView.Id);
	ElementClassFilter ECF = new ElementClassFilter(typeof(Grid));
	List<Grid> Grids = FEC.WherePasses(ECF).ToElements().Cast<Grid>().ToList();
	const bool ShowGridBubbleLeft = true;
	const bool ShowGridBubbleTop = true;
	using (Transaction Tr = new Transaction(Doc, "Line up those grid bubbles"))
		if (Tr.Start() == TransactionStatus.Started)
			foreach (Grid Gr in Grids)
				Line crv = Gr.Curve as Line;
				if (crv == null)
					continue;
				//Line curves only
				XYZ[] EP = new XYZ[] {
				Tx.Inverse.OfPoint(crv.GetEndPoint(0)),
				Tx.Inverse.OfPoint(crv.GetEndPoint(1))
				if (Math.Abs(EP[0].X - EP[1].X) > Math.Abs(EP[0].Y - EP[1].Y))
					//More horizontal than vertical
					if (EP[0].X > EP[1].X)
						if (ShowGridBubbleLeft)
							Gr.ShowBubbleInView(DatumEnds.End1, AcView);
							Gr.HideBubbleInView(DatumEnds.End0, AcView);
						else
							Gr.ShowBubbleInView(DatumEnds.End0, AcView);
							Gr.HideBubbleInView(DatumEnds.End1, AcView);
					else
						else
				else
					//More vertical than horizontal or perhaps 45 degrees (Dx=Dy)
					if (EP[0].Y > EP[1].Y)
						if (ShowGridBubbleTop)
						else
					else
						else
			Tr.Commit();
C#
 Private Function TObj73(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        If commandData.Application.ActiveUIDocument Is Nothing Then Return Result.Cancelled Else
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim Doc As Document = UIDoc.Document
        Dim AcView As ViewPlan = TryCast(UIDoc.ActiveGraphicalView, ViewPlan)
        If AcView Is Nothing Then Return Result.Cancelled Else
        Dim Tx As Transform = Transform.Identity
        Dim FEC As New FilteredElementCollector(Doc, AcView.Id)
        Dim ECF As New ElementClassFilter(GetType(Grid))
        Dim Grids As List(Of Grid) = FEC.WherePasses(ECF).ToElements.Cast(Of Grid).ToList
        Const ShowGridBubbleLeft As Boolean = True
        Const ShowGridBubbleTop As Boolean = True
        Using Tr As New Transaction(Doc, "Line up those grid bubbles")
            If Tr.Start = TransactionStatus.Started Then
                For Each Gr As Grid In Grids
                    Dim crv As Line = TryCast(Gr.Curve, Line)
                    If crv Is Nothing Then Continue For Else 'Line curves only
                    Dim EP As XYZ() = New XYZ() {Tx.Inverse.OfPoint(crv.GetEndPoint(0)),
                                         Tx.Inverse.OfPoint(crv.GetEndPoint(1))}
                    If Math.Abs(EP(0).X - EP(1).X) > Math.Abs(EP(0).Y - EP(1).Y) Then
                        'More horizontal than vertical
                        If EP(0).X > EP(1).X Then
                            If ShowGridBubbleLeft Then
                            Else
                        Else
                            Else
                    Else
                        'More vertical than horizontal or perhaps 45 degrees (Dx=Dy)
                        If EP(0).Y > EP(1).Y Then
                            If ShowGridBubbleTop Then
                            Else
                        Else
                            Else
                Next
                Tr.Commit()
        End Using
        Return Result.Succeeded
    End Function
 Much easier to read VB
Thank you very much!
