Log to Nlog console
Log to Nlog console
MGO-Norsyn
Log to Nlog console
MGO-Norsyn
Does anyone know how to make Nlog console logging work with Revit?
I can make it work with a file target, but if I setup a target for console nothing happens.
I was thinking about the fancy log console that pyRevit has, but I cannot find any guides on how to implement console logging in Revit using Nlog.
jeremytammik
The pyRevit code is open source.
The RevitPythonShell also has a nice console similar to what you describe, also open source.
Basically, you simply open a modeless window and write text to it from your add-in.
Jeremy Tammik
Developer Technical Services
The Building Coder
