Managed Debugging Assistant 'FatalExecutionEngineError'
info25S94
info25S94
I get the following error, when I'm trying to debug revit add-in using visual studio:
info25S94
Nothing of these solved my issue. The same problem still exist.
info25S94
Can anyone help?
I have the same problem and it didn't work from me too.
none of these worked for me too... Any other updates on this?
luisPDAN6
If there is another plugin loading in Revit and that was not compiled as release, but as debug, we may also get this error as "Just my code" is selected.
'Revit.exe' (CLR v4.0.30319: DefaultDomain): Loaded 'C:\Program Files\Toolbox\Toolbox.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
Removing the other plugin then solves the issue and Revit loads correctly. My conclusion is that it can only be 1 plugin compiled as debug if the "Just my code" is enabled. And that option is important otherwise we get exceptions of all the other plugins...
