Get the Type's name of DuctType from Revit API.
akarahay
1,267 次查看
7 条回复
1 条消息(共 8 条)
akarahay
When drawing the duct, we have access to the type of each duct type with different routing preferences, see screen shot. How can we access the name of the type of round duct for example Round Duct with Taps or Tee version of the duct type?
Currently, I can access only the FamilyName, but not the element's name like Tees, for the round duct. Pleas advise!
doc=DocumentManager.Instance.CurrentDBDocument
# Filter for MEPCurveType
FamCollector=FilteredElementCollector(doc).OfClass(MEPCurveType)
for Fam in FamCollector:
    FamilyT.append(Fam.FamilyName)
    #Select only hard Duct not flex duct
    if "Duct" in Fam.FamilyName and "Flex" not in Fam.FamilyName:
        DuctFamily.append(Fam.FamilyName)
已接受的解答 (2)
1,268 次查看
7 条回复
回复 (7)
2 条消息(共 8 条)
architect.bim
已接受的解答
Hi!
Actually the only thing you need is to get the Name Property value. But if you are dealing with IronPython it will cause an Exception due to the specifics of this language. But there is a workaround, see the code below:
import clr
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import FilteredElementCollector, Element
from Autodesk.Revit.DB.Mechanical import DuctType
doc = __revit__.ActiveUIDocument.Document
duct_types = FilteredElementCollector(doc).OfClass(DuctType)
for duct_type in duct_types:
    print Element.Name.GetValue(duct_type)
Maxim Stepannikov | Architect, BIM Manager, Instructor
3 条消息(共 8 条)
akarahay
Hi Max
Thanks for the solution! Actually, I am working Python Script in Dynamo, not in C#.  The Error was "The property cannot be read", using the method you have suggested (DuctType.Name was not allowed). Would you mind elaborating on the workaround in IronPython to get the value property of the Name of the duct type.
0 个赞
4 条消息(共 8 条)
architect.bim
Hi!
The code I have provided you written exactly in Python. And the workaround is the last line code:
0 个赞
5 条消息(共 8 条)
architect.bim
已接受的解答
By the way, there is also another workaround. You can get the value of the "Type Name" parameter. But for me personally, the first variant makes more sense than this one.
duct_type.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString()
6 条消息(共 8 条)
akarahay
Thank again, Max! This line works for me: duct_type.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString() .
But the "Element.Name.GetValue(duct_type)" still give me error. See screenshot below.
import clr
import sys
import System
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
#import Revit API
import Autodesk
from Autodesk.Revit.DB import *
#from Autodesk.Revit.DB import FilteredElementCollector, Element
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
DuctTypeName=[]
ListDuctType=[]
#Get Current Project Doc
doc = DocumentManager.Instance.CurrentDBDocument
FamCollector=FilteredElementCollector(doc).OfClass(DuctType)
for Dt in FamCollector:
    if "Duct" in Dt.FamilyName and "Flex" not in Dt.FamilyName:
        DuctTypeName.append(Dt.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString())
        ListDuctType.append(Element.Name.GetValue(Dt))
OUT=DuctTypeName,ListDuctType
7 条消息(共 8 条)
architect.bim
Oh I see. This happens because you are using CPython3 to run the code. It causes many issues. If you switch to Ironpython2 at the bottom of the Python Script node, it will definitely work (in latest versions of Revit and Dynamo there might be no Ironpython at the bottom, in that case you should install additional Dynamo package to use Ironpython2)
0 个赞
8 条消息(共 8 条)
akarahay
After switching to IronPyhon2, it works! Thanks, Max! Really appreciate your help!
