Creating a family instance on a face from a link
itayP62BG
Observer Observer
itayP62BG
Observer
Observer
I'm currently working on a project in Revit API, and I'm having some trouble creating a new family instance on a face from a linked model. Specifically, I'm trying to place a family on a face in a linked model, but I can't seem to make it work.
I'm using the NewFamilyInstance method but it doesn't work when I give it a linked face or a reference from this face
I would be glad if anyone has an answer to this issue.
jeremy_tammik
I know this has been discussed repeatedly in the past, so you ought to be able to find existing discussions and solutions yourself.
I searched this forum for "instance link" and found this:
Does it help?
If not, I am sure there are several other relevant conversations to explore...
itayP62BG
Observer
Observer
Thanks for the quick answer,
This question doesn't really answer me because I'm looking to create the instance on a face and not a wall or any other element. I will look more in the forum
Thanks again
jeremy_tammik
In the Revit BIM, all faces belong to some building element, e.g., a wall or some other host. So, if you place an instance on a face, you must be placing it on a wall or some other host element.
If this is unclear, please research your approach thoroughly in the end user interface, manually, without programming, and explore the optimal workflow and best practices in that environment first.
