Disable Updater with ExternalCommand
Nathan.HilsonN67V6
Nathan.HilsonN67V6
I'm running into a similar issue same as this post.
Solved: Disable or enable updater - Autodesk Community - Revit Products
I keep getting the object reference isn't set to an instance when it clearly is unless I'm missing something that's going on internally. Below is the command that I'm using:
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            try
                //UpdaterRegistry.DisableUpdater(new assemblyLockUpdater.GetUpdaterId());
                //UpdaterRegistry.UnregisterUpdater(new AssemblyLockUpdaterId(application.ActiveAddInId).GetUpdaterId());
                //UpdaterRegistry.RemoveAllTriggers(assemblyLockUpdater.GetUpdaterId());
                //UpdaterRegistry.EnableUpdater(assemblyLockUpdater.GetUpdaterId());
                UpdaterRegistry.DisableUpdater(assemblyLockUpdater.GetUpdaterId());
                return Result.Succeeded;
            catch(Exception e)
                MessageBox.Show(e.Message);
                return Result.Failed;
This is how I have it registered in the application:
                UtilsAssemblyLock.AssemblyLockUpdaterId assemblyLockUpdater =
                new UtilsAssemblyLock.AssemblyLockUpdaterId(application
                    .ActiveAddInId);
                UpdaterRegistry.RegisterUpdater(assemblyLockUpdater, true);
                UpdaterRegistry.AddTrigger(
                    assemblyLockUpdater.GetUpdaterId(),
                    new ElementClassFilter(typeof(FabricationPart)),
                    Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.FABRICATION_PART_WEIGHT)));
                UtilsAssemblyLock.assemblyLockedFailureId =
                    new FailureDefinitionId(Guid.NewGuid());
                FailureDefinition.CreateFailureDefinition(
                    UtilsAssemblyLock.assemblyLockedFailureId,
                    FailureSeverity.Error,
                    "S.A.I.: \n" + "Cannot edit assembly without permission.";
Kennan.Chen
I don't see where the assemblyLockUpdater instance get initialized in you external command.
Nathan.HilsonN67V6
I created that in a separate class. The updater works fine it's just disabling it that I'm having issues with:
    public class UtilsAssemblyLock
        public static FailureDefinitionId assemblyLockedFailureId;
        public class AssemblyLockUpdaterId : IUpdater
            private readonly UpdaterId assemblyLockUpdaterId;
            private FabricationDimensionDefinition _dimensionDefinition;
            public AssemblyLockUpdaterId(AddInId id)
                assemblyLockUpdaterId = new UpdaterId(id, new Guid("7595F412-275B-4F65-A354-7F9CB439283B"));
            public void Execute(UpdaterData data)
                try
                    Document doc = data.GetDocument();
                    List<ElementId> ids = new List<ElementId>();
                    ids.AddRange(data.GetAddedElementIds());
                    ids.AddRange(data.GetModifiedElementIds());
                    ids.AddRange(data.GetDeletedElementIds());
                    foreach (ElementId id in ids)
                        if (doc.GetElement(id) is FabricationPart fabricationPart)
                            if (!data.IsChangeTriggered(id, Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.FABRICATION_PART_WEIGHT))))
                                break;
                            if (!fabricationPart.IsValidObject)
                                continue;
                            #region Elements Are Assembled
                            if (!fabricationPart.AssemblyInstanceId.IsNull())
                                Console.Beep();
                                AssemblyPassword assemblyPasswordForm = new AssemblyPassword();
                                assemblyPasswordForm.ShowDialog();
                                if (assemblyPasswordForm.assemblyPasswordEntry() == "1234" ||
                                    assemblyPasswordForm.assemblyPasswordEntry() == "abcd")
                                else
                                    FailureMessage failureMessage = new FailureMessage(assemblyLockedFailureId);
                                    failureMessage.SetFailingElement(id);
                                    doc.PostFailure(failureMessage);
                            #endregion
                catch (Exception ex)
                    MessageBox.Show(ex.Message);
            public UpdaterId GetUpdaterId()
                UpdaterId id = assemblyLockUpdaterId;
                return (id);
            public ChangePriority GetChangePriority()
                return ChangePriority.MEPSystems;
            public string GetUpdaterName()
                return "Fabrication Assembly Updater";
            public string GetAdditionalInformation()
                return "Fabrication Pipe Assembly updater example: checks to make sure Pipe that has been assembled " +
                    "is not edited.";
Kennan.Chen
You use it directly in your external command. I don't see any connection between your command and the AssemblyLockUpdaterId class. Can you provide all the code of your external command?
Nathan.HilsonN67V6
I was trying a few things out so it's not currently functional:
    [Transaction(TransactionMode.Manual)]
    public class AssemblyUpdaterId : IExternalCommand
        private static UtilsAssemblyLock.AssemblyLockUpdaterId assemblyLockUpdater;
        private static UtilsAssemblyLock utilsAssemblyLock;
        public static bool enable;
        public static void DisableUpdater(UtilsAssemblyLock utilsAssemblyLock)
           var utilsAssemblyLockUpdater = utilsAssemblyLock;
            if (utilsAssemblyLockUpdater != null)
                enable = false;
            enable = false;
            return;
        public static UIControlledApplication application;
            try
            catch(Exception e)
Nathan.HilsonN67V6
Figured it out. I added a constructor to the utility class & cleaned up my command class. Here's both.
//Command
        //[Journaling(JournalingMode.NoCommandData)]
        public class DissableAssemblyLock : IExternalCommand
                var transaction = new Transaction(commandData.Application.ActiveUIDocument.Document, "Dissable Assembly Lock");
                using (transaction)
                    if (transaction.Start() == TransactionStatus.Started)
                        try
                        UpdaterRegistry.DisableUpdater(new AssemblyLockUpdaterId(commandData.Application.ActiveAddInId).GetUpdaterId());
                        catch (Exception e)
                        finally
                            transaction.Commit();
//Utility Class
            public AssemblyLockUpdaterId()
                try
                                break;
                                continue;
                                Console.Beep();
                                else
                            #endregion
                return (id);
                    "is not edited.";
