I am trying to gather Grand Totals from multiple Schedules for Calculated Fields.
Revit natively does not support multi-category schedule where I could aggregate for example cost for different values. For example Cost per piece, Cost per meter, Cost per square meter etc. So I have multiple schedules and then I am trying to get Grand totals for each of these schedules.
The Column is Calculated Field with Type: Currency, set to "Calculate Totals".
The Field is also Formatted in Schedule to use Unit symbol 123€.
I can get string value of the Grand Total like this:
TableData tableData = schedule.GetTableData();
TableSectionData tableSection = tableData.GetSectionData(SectionType.Body);
string cellText = schedule.GetCellText(SectionType.Body, tableSection.LastRowNumber, tableSection.LastColumnNumber);
But with this there are few problems:
1) It's hard to Parse the string to add multiple int of multiple schedules. If the User Formats the Field with different Prefix/Suffix there might be problems.
2) If the Grand Total Column is not the last column, it won't read the value. (ok, I can set instructions, but it is still very constrained)
To tackle first problem, I try to use
TableCellCalculatedValueData tableCellCalculatedValueData = tableSection.GetCellCalculatedValue(rowIndex, columnIndex);
But this just returns Null for every cell - although I clearly have Calculated Fields. And even if it returned value, the TableCellCalculatedValueData is nonsense Type with no value Properties.
So the questions are -
1) Is there a way to get Grand Totals for schedules as values?
2) how to get Calculated Cell Value without formatting?
p.s. I have read the https://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
edit: After iterating through all cells to get: CellType cellType = tableSection.GetCellType(rowIndex, columnIndex);
it seems like the Grand Total is CellType .Text. But the same Column Cell with value is CellType.ParameterText (Read only parameter which only show formatted string)
Not being a Revit power end-user, my approach would be to just grab the data that you can get, regardless of formatting, suffixes, and other junk, and then deal with that as it comes. For me, handling the string formatting and parsing sounds like a simpler task than trying to coerce Revit to do the job for you. I will happily hear what the power users can suggest to further simplify things for you, though.
This is what I come up so far. It works, but it does not fix the issue that Grand Total should be the last Column.
public double ExtractGrandTotal(ViewSchedule schedule)
ScheduleDefinition scheduleDefinition = schedule.Definition;
if (!scheduleDefinition.ShowGrandTotal)
return 0.0;
TableSectionData bodySection = tableData.GetSectionData(SectionType.Body);
if (bodySection == null)
return 0.0;
return TryGetGrandTotalFromLastCell(schedule, bodySection);
private double TryGetGrandTotalFromLastCell(ViewSchedule schedule, TableSectionData bodySection)
int lastRowNumber = bodySection.LastRowNumber;
int lastColumnNumber = bodySection.LastColumnNumber;
string cellText = schedule.GetCellText(SectionType.Body, lastRowNumber, lastColumnNumber);
ForgeTypeId cellSpec = bodySection.GetCellSpec(lastRowNumber, lastColumnNumber);
if (IsCellValidForParsing(cellSpec))
Units documentUnits = _document.GetUnits();
Debug.WriteLine($"Trying to parse string: {cellText}");
if (UnitFormatUtils.TryParse(documentUnits, cellSpec, cellText, out double grandTotal))
Debug.WriteLine($"Parsed value: {grandTotal}");
return grandTotal;
return 0.0;
private bool IsCellValidForParsing(ForgeTypeId cellSpec)
return cellSpec != null && !string.IsNullOrEmpty(cellSpec.TypeId) && UnitUtils.IsMeasurableSpec(cellSpec);
Indeed it would be great to hear from Revit power end-users.
