Create Floor from Wall
reylorente1
reylorente1
Tengo este script,que funciona en el revit 2021.Pero al cambiar al Revit 2022,cambia el metodo de creacion del suelo.
Alguna idea de como solucionarlo?
Aqui esta el script
I have this script, it works in revit 2021, but when switching to revit 2022, it changes the method of creating the floor.
Any idea how to fix it?
Here is the script
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Result result = Result.Succeeded;
            //Get UIDocument and Document
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            //Initialize wall selection filter
            WallSelectionFilter wallSelection = new WallSelectionFilter();
            //Select the walls
            IList<Reference> references = uidoc.Selection.PickObjects(Autodesk.Revit.UI.Selection.ObjectType.Element, wallSelection);
            if (references != null && references.Count > 0)
                //Initialize the curves list
                List<Curve> wallCurves = new List<Curve>();
                //Initialize the offsets list
                List<double> offsets = new List<double>();
                //Initialize the levels ids list
                List<ElementId> levelsIds = new List<ElementId>();
                foreach (var refer in references)
                    Wall wall = (Wall)doc.GetElement(refer);
                    if (wall != null)
                        //Add the wall curve to the curves list
                        wallCurves.Add((wall.Location as LocationCurve).Curve);
                        //Add the wall curve to the curve list
                        offsets.Add(wall.Width / 2.0);
                        levelsIds.Add(wall.LevelId);
                    if (levelsIds.All(lvl => lvl == levelsIds[0]))
                        CurveLoop ccu = CurveLoop.Create(wallCurves);
                        //Create floor curve loop
                        CurveLoop ccud = CurveLoop.CreateViaOffset(ccu, offsets,new XYZ(0, 0, 1));
                        //Initialize the curve array
                        CurveArray curveArray = new CurveArray();
                        //Append the floor curves to the curve array
                        foreach (Curve c in ccud)
                            curveArray.Append(c);
                        //Get the level to model the floor
                        Level level = doc.GetElement(levelsIds[0]) as Level;
                        string floorTypeName = "Generic 300mm";
                        //Collect the floor type to be used
                        FloorType floorType = new FilteredElementCollector(doc).OfClass(typeof(FloorType))
                            .First(e => e.Name.Equals(floorTypeName)) as FloorType;
                        using (Transaction tx = new Transaction(doc, "Wall to Floor"))
                            tx.Start();
                            try
                                //Create the floor
                                doc.Create.NewFloor(curveArray, floorType, level, false);// Revit API 2021
                                Floor.Create(doc, new List<CurveLoop> { ccud }, floorType.Id, level.Id);// Revit API 2022
                                //Commintchange to the model
                                tx.Commit();
                            catch (Exception e)
                                //Asign the error message to the user
                                message = e.Message;
                                //Roll back the model changes
                                tx.RollBack();
                                //Asign the result to failed
                                result = Result.Failed;
                    else
            else
            return result;
bhprest
Yes, the Document.NewFloor() methods have been deprecated in the 2022 API, and replaced with the Floor.Create() methods.
You'll need to check which version of the application is running, and account for it inside your code. How you manage this ultimately depends on how you handle multi-targeting.
anh00908668qv6e
Observer
Observer
Hello, I would like to ask if you still have this project folder. Could you please share it with me for reference? I am currently working on an assignment related to this topic!!
reylorente1
Si claro, pero no fue una carpeta, simplemente lo vi en algún lado, y lo quise reproducir.
Aqui está la solución correcta:
Yes, of course, but it wasn't a folder, I simply saw it somewhere, and I wanted to play it. Here is the correct solution:
  ref string message,
    UIApplication uiapp = commandData.Application;
    UIDocument uidoc = uiapp.ActiveUIDocument;
    Application app = uiapp.Application;
    //Select the walls
        IList<double> offsets = new List<double>();
            if (wall != null)
            CurveLoop ccud = CurveLoop.CreateViaOffset(ccu, offsets, new XYZ(0, 0, 1));
                tx.Start();
                try
                    //Create the floor
                    //doc.Create.NewFloor(curveArray, floorType, level, false);// Revit API 2021
                    tx.Commit();
                catch (Exception e)
                    tx.RollBack();
        else
    else
    return result;
 public class WallSelectionFilter : ISelectionFilter
     public bool AllowElement(Element elem)
         return elem is Wall;
     public bool AllowReference(Reference reference, XYZ position)
         return false;
Also in Revit 20... SDK, there is an example called, GenerateFloor. The ellipsis, depends on the year
anh00908668qv6e
Observer
Observer
Thanks a lot!!!
