add length, width, and height to schedule floors
1015253CBBFL
1015253CBBFL
Community Visitor
Community Visitor
Hello, I would like to include length, width, and height parameters in my floor schedule. Could you please guide me on how to add these fields?
jeremy_tammik
Sure. I see lots of explanations searching the Internet for "revit add field to schedule":
reylorente1
Check this link. https://twentytwo.space › 2021 › 05 › 02 › revit-api-schedule-creation. Although it is for walls, it can give you a guide
TripleM-Dev.net
Hi @1015253CBBFL,
For height you mean thickness, there are the Core Thickness and Default thickness fields already available.
Maybe even elevation at top/bottom can be used to calculate height if sloped ?
For length and width I always wonder what's the purpose of it, as a floor (and roof/ceiling) can have non-rectangular shapes and what if it has angled boundaries....area or volume would have more meaning.
So for Length/width I would rather use max_length/max_width....
Is the question about how to add parameters to a project (for the floor category) or on how to fill the parameters with values for the floors.
Or is on how to create a schedule in the API and add those parameters?
riaan_boshoff
Community Visitor
Community Visitor
Some floor shapes are indeed rectangular and it will be nice to extract lengths or widths for measuring purposes
jeremy_tammik
For rectangular shapes, obtaining width and length is pretty easy, even if the data is not stored directly in separate parameter values; you can query the floor element for its slab geometry and determine the lengths of all horizontal edges; the width and length should occur four times each on the 8 horizontal slab edges; four on the bottom face, four on the top.
