Hi
I need to get the lenght of a cable tray fittings.
I could get lenght betwen connector A and B but this is not a correct method.
I'd like to get length of an arc between passing by A and B with center of BendRadius...
But how to get the center with API?
This may be somewhat tricky due to the fact that every content creator is free to set up the elbow fitting family definition as she pleases. So, it is hard to know what parameters are available and what they might mean. My off-hand suggestion to approach this would be the following:
That is the best approximation I can think of offhand. If you have the bend width, radius, straight line extensions at the two ends of the bend, and/or other additional data, you can improve the calculation taking those into account.
Hi Jeremy
and thanks for replying
Thanks for the hint
Indeed, I think the idea would be to find the center of a circle from the two connectors. I'd need to get the vectors at these points and take the perpendicular to these vectors. Then I could find their intersection and draw an arc between the two connectors.
But how do I get the vectors? By using the Transform object and then BasisXYZ?
Yes, exactly. In the CoordinateSystem property, the coordinate system origin is the location of the connector and the Z-axis is normal to the connector, and thus also to the fitting face hosting it, and thus also collinear with the neighbouring conduit location line:
I found this post from Cyril Poupin in Python ...
The code said :
pair_sys_origin = [[con.CoordinateSystem, con.Origin] for con in conSet]
pta = pair_sys_origin[0][1].ToPoint()
ptb = pair_sys_origin[1][1].ToPoint()
vector = pair_sys_origin[0][0].BasisZ.Negate().ToVector()
arc = DS.Arc.ByStartPointEndPointStartTangent(pta, ptb, vector)
return arc, arc.Length
I've tried to translate it in C#
But I don't have good result because Dynamo API got this function called ByStartPointEndPointStartTangent and I must creat my own .... mmm...this is a geometric problem..
//méthode à partir de deux connecteurs
if (connectors.Size == 2)
//Transforme le Set en liste
var castConnectors = connectors.Cast<Connector>();
List<Connector> connectorList = castConnectors.ToList();
//get first point
Transform transformPtA = connectorList[0].CoordinateSystem;
XYZ originPtA = transformPtA.Origin;
//get Vector from this point
XYZ vector = transformPtA.BasisZ.Negate();
//get second point
Transform transformPtB = connectorList[1].CoordinateSystem;
XYZ originPtB = transformPtB.Origin;
//Get arc from those points
Arc arc = Arc.Create(originPtA, originPtB, vector);
length = arc.Length;
I thing you need to do it manually but but of course programmatically 🙂 . I mean there is no direct way to get it. So you need to identify the two connectors for which you want to determine the outer radius. From these 2 connectors we extract the origin points. The points are crucial for finding the center point of the arc.
Getting the center point can be reached by drawing a perpendicular line to the cable tray curve direction and projecting the second point onto this line, by which we can locate the center.
Next, draw an arc connecting the two points with the radius. The radius can be measured by getting the distance between any of the connectors to the center point we evaluated. This approach will establish the centerline connection between the two MEP curves. Finally, by using the CreateOffset function with a distance equal to half the cable tray width, we can achieve our desired outcome.
Below is a sample code that summarizes the process, you need to take care of the angles needed to draw the arc. The start angle has to be less than the end angle. Another thing I noticed in most of MEP Fittings, specially the elbow kind, the path that is used to sweep the profile, is composed of two lines and one arc. the two lines gives a smooth connection like when used. so you need also to take care of the such thing, in order to get an accurate result.
Finally, I quickly written the sample below for the 90 degrees case. I think in the other angle cases, you need to take care of the projection of the second point. probably you need to create another perpendicular line and find the intersection between the two lines.
Let us know your findings.
// assuming you already have the two connectors.
// we get the curves lines from its owner.
var horizontalLine = ((LocationCurve)connectorA.Owner.Location).Curve as Line;
var verticalLine = ((LocationCurve)connectorB.Owner.Location).Curve as Line;
// catch the distance and location of the 2 connectors and the distance between
var originA = connectorA.Origin;
var originB = connectorB.Origin;
var diagonalDistance = originA.DistanceTo(originB);
// get the sketchplan used to draw such cable trays
var sketchPlan = SketchPlane.Create(Doc, ((MEPCurve)connectorA.Owner).ReferenceLevel.Id).GetPlane();
// now we need draw a perpendicular line to any of the mep curves.
var perDirection = horizontalLine.Direction.CrossProduct(sketchPlan.Normal);
var perpL1 = Line.CreateBound(originA - perDirection * diagonalDistance, originA + perDirection * diagonalDistance);
// then project the second point over this perpendicular curve to get the center point
var centerPoint = perpL1.Project(originB).XYZPoint;
// arc requires 2 angles start and end
double angleX = sketchPlan.XVec.AngleTo((originA - centerPoint).Normalize());
double angleY = sketchPlan.XVec.AngleTo((originB - centerPoint).Normalize());
// draw the arc <= this is in the zero position "sketchplan origin point"
Curve arc = Arc.Create(sketchPlan, originB.DistanceTo(centerPoint), angleX, angleY);
// move the arc to the center point
arc = arc.CreateTransformed(Transform.CreateTranslation(centerPoint));
// create the offset needed to get the outer Radius
arc = arc.CreateOffset(((MEPCurve)connectorA.Owner).Width / 2, sketchPlan.Normal);
Hi @Moustafa_K
thx for your answer
I’ll test it soon
It’s a shame because I’m sure the solution is in the api Dynamo function called ByStartPointEndPointStartTangent but no way to find source code
Pipe elbow fittings often have a straight segment on each side before the arc begins, for connecting them to the neighbour parts. Do the conduit elbows always connect immediately to the arc, with no straight segment before and after?
I'm getting ahead of myself
I reach the center of my arc.
However, I'm stuck on creating the arc.
My bow doesn't always go in the right direction and it doesn't go between my two connector points...
Connector connectorA = connectorList[0];
Connector connectorB = connectorList[1];
#region connectorA_Perpendicular
//get Transform
Transform transformPtA = connectorA.CoordinateSystem;
//get origin
//get direction
XYZ directionA = (connectorA.Owner.Location as LocationPoint).Point;
//set line between origin and direction of owner
Line lineA = Line.CreateBound(originPtA, directionA);
//get perpendicular
XYZ normalA = lineA.Direction.Normalize();
XYZ dirA = new XYZ(0, 0, 1);
XYZ crossA = normalA.CrossProduct(dirA);
XYZ endA = originPtA + crossA.Multiply(4);
XYZ endAMirror = originPtA + crossA.Multiply(-4);
Line linePerpendicularA = Line.CreateBound(endA, endAMirror);
#endregion
#region connectorB_Perpendicular
//get Transform
Transform transformPtB = connectorB.CoordinateSystem;
//get origin
//get direction
XYZ directionB = (connectorB.Owner.Location as LocationPoint).Point;
Line lineB = Line.CreateBound(originPtB, directionB);
//get perpendicular
XYZ normalB = lineB.Direction.Normalize();
XYZ dirB = new XYZ(0, 0, 1);
XYZ crossB = normalB.CrossProduct(dirB);
XYZ endB = originPtB + crossB.Multiply(4);
XYZ endBMirror = originPtB + crossB.Multiply(-4);
Line linePerpendicularB = Line.CreateBound(endB, endBMirror);
#endregion
//get intersection between perpendiculars
XYZ centerOfArc = null;
IntersectionResultArray intersectionResults = new IntersectionResultArray();
SetComparisonResult setCR = linePerpendicularA.Intersect(linePerpendicularB, out intersectionResults);
if (setCR == SetComparisonResult.Overlap)
if (intersectionResults != null && intersectionResults.Size == 1)
//there is one point interesction
IntersectionResult iResult = intersectionResults.get_Item(0);
centerOfArc = iResult.XYZPoint;
_geometries.Add(Point.Create(centerOfArc));
if (centerOfArc != null)
//Set arc from point A and B
double radius = centerOfArc.DistanceTo(originPtA);
XYZ xAxis = new XYZ(1, 0, 0); // The x axis to define the arc plane. Must be normalized
XYZ yAxis = new XYZ(0, 1, 0); // The y axis to define the arc plane. Must be normalized
Arc arc = Arc.Create(centerOfArc, radius, 0, Math.PI / 2.0, xAxis, yAxis);
_geometries.Add(arc);
And what about Cable Tray Fittings which are vertical or visible in section like this?
HI @Moustafa_K @SONA-ARCHITECTURE @jeremy_tammik
I found a new workaround to get the center curve of the duct, I don't whether anybody document it or not. I have use the complete Revit API library to create Arc. Kindly check the below code for additional reference.
Reference Code
ElementId id = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element).ElementId;
FamilyInstance inst = doc.GetElement(id) as FamilyInstance;
Options opt = new Options();
opt.ComputeReferences = true;
opt.DetailLevel = ViewDetailLevel.Coarse;
GeometryElement geoElement = inst.get_Geometry(opt);
using (Transaction createArc = new Transaction(doc, "Create Arc"))
createArc.Start();
foreach (GeometryInstance geoInst in geoElement)
if(geoInst != null)
foreach (GeometryObject obj in geoInst.GetInstanceGeometry())
if (obj is Arc)
doc.Create.NewModelCurve(obj as Curve, SketchPlane.
Create(
doc,
Plane.CreateByNormalAndOrigin((obj as Arc).Normal,
(obj as Arc).GetEndPoint(0))));
createArc.Commit();
Reference GIF
Hope this will Helps 🙂
YouHou!!! It works!!
So yes, depending on the level of view detail, the instances returned by GetInstanceGeometry are not the same.
Secret is changing the ViewDetailLevel to Coarse!
The good surprise is that Arc or Line have an ApproximateLength property, so I don't have to run a transaction.
The code looks like this
foreach (ElementId elemId in _uidoc.Selection.GetElementIds())
// normalement, un seul
Element element = _uidoc.Document.GetElement(elemId);
if (element.GetType() == typeof(FamilyInstance))
double approximateLength = 0;
FamilyInstance famInst = element as FamilyInstance;
GeometryElement geoElement = famInst.get_Geometry(opt);
if (geoInst != null)
foreach(GeometryObject geoObj in geoInst.GetInstanceGeometry())
if (geoObj is Arc)
Arc arc = geoObj as Arc;
approximateLength += arc.ApproximateLength;
if (geoObj is Line)
Line line = geoObj as Line;
approximateLength += line.ApproximateLength;
TaskDialog.Show("Message from dev", "Approximate length of instance is " +
UnitUtils.ConvertFromInternalUnits(approximateLength, UnitTypeId.Centimeters));
Thanks to all
On the other hand, I'm very disappointed that I wasn't able to calculate all this using vectors... Maybe another time.
Thanks @jeremy_tammik and @Moustafa_K for your help!
And thanks to Mariyan for his tutos about vectors!
https://youtu.be/FrFSPTRO9wY?si=i3HvK-IT908ST8QO
