I thing you need to do it manually but but of course programmatically 🙂 . I mean there is no direct way to get it. So you need to identify the two connectors for which you want to determine the outer radius. From these 2 connectors we extract the origin points. The points are crucial for finding the center point of the arc.
Getting the center point can be reached by drawing a perpendicular line to the cable tray curve direction and projecting the second point onto this line, by which we can locate the center.
Next, draw an arc connecting the two points with the radius. The radius can be measured by getting the distance between any of the connectors to the center point we evaluated. This approach will establish the centerline connection between the two MEP curves. Finally, by using the CreateOffset function with a distance equal to half the cable tray width, we can achieve our desired outcome.
Below is a sample code that summarizes the process, you need to take care of the angles needed to draw the arc. The start angle has to be less than the end angle. Another thing I noticed in most of MEP Fittings, specially the elbow kind, the path that is used to sweep the profile, is composed of two lines and one arc. the two lines gives a smooth connection like when used. so you need also to take care of the such thing, in order to get an accurate result.
Finally, I quickly written the sample below for the 90 degrees case. I think in the other angle cases, you need to take care of the projection of the second point. probably you need to create another perpendicular line and find the intersection between the two lines.
Let us know your findings.
// assuming you already have the two connectors.
// we get the curves lines from its owner.
var horizontalLine = ((LocationCurve)connectorA.Owner.Location).Curve as Line;
var verticalLine = ((LocationCurve)connectorB.Owner.Location).Curve as Line;
// catch the distance and location of the 2 connectors and the distance between
var originA = connectorA.Origin;
var originB = connectorB.Origin;
var diagonalDistance = originA.DistanceTo(originB);
// get the sketchplan used to draw such cable trays
var sketchPlan = SketchPlane.Create(Doc, ((MEPCurve)connectorA.Owner).ReferenceLevel.Id).GetPlane();
// now we need draw a perpendicular line to any of the mep curves.
var perDirection = horizontalLine.Direction.CrossProduct(sketchPlan.Normal);
var perpL1 = Line.CreateBound(originA - perDirection * diagonalDistance, originA + perDirection * diagonalDistance);
// then project the second point over this perpendicular curve to get the center point
var centerPoint = perpL1.Project(originB).XYZPoint;
// arc requires 2 angles start and end
double angleX = sketchPlan.XVec.AngleTo((originA - centerPoint).Normalize());
double angleY = sketchPlan.XVec.AngleTo((originB - centerPoint).Normalize());
// draw the arc <= this is in the zero position "sketchplan origin point"
Curve arc = Arc.Create(sketchPlan, originB.DistanceTo(centerPoint), angleX, angleY);
// move the arc to the center point
arc = arc.CreateTransformed(Transform.CreateTranslation(centerPoint));
// create the offset needed to get the outer Radius
arc = arc.CreateOffset(((MEPCurve)connectorA.Owner).Width / 2, sketchPlan.Normal);
Moustafa Khalil
