Get all associated Rebars which attach to the Structural Element
Hi
How can i get all associated Rebars which attach to the Structural Element such as a column by picking that?
jeremytammik
Use a filtered element collector.
Set it up to retrieve rebar elements only, and add a filter for the column solid:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks @jeremytammik
But the example of the link is for VB,
I used this code, but couldn't get answer,
Reference pickedObj = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element);
            ElementId eleId = pickedObj.ElementId;
            Element ele = doc.GetElement(eleId);
            IEnumerable<Element> associatedElement = new FilteredElementCollector(doc).OfClass(typeof(FamilyInstance)).OfCategory(BuiltInCategory.OST_Rebar)
                .Where(m => (m as FamilyInstance).Host.Id == eleId);
foreach (var item in associatedElement)
                MessageBox.Show(item.get_Parameter(BuiltInParameter.REBAR_INSTANCE_BAR_DIAMETER).ToString());
 where is the problem?
jeremytammik
Is the Host property set at all?
I don't know.
Have you checked that?
Have you installed and used RevitLookup?
What I meant was to use a solid intersection filter, cf. GetInstancesIntersectingElement:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
    #region Retrieve family instances intersecting BIM element
    /// <summary>
    /// Retrieve all family instances intersecting a
    /// given BIM element, e.g. all columns
    /// intersecting a wall.
    /// </summary>
    void GetInstancesIntersectingElement( Element e )
      Document doc = e.Document;
      Solid solid = e.get_Geometry( new Options() )
        .OfType<Solid>()
        .Where<Solid>( s => null != s && !s.Edges.IsEmpty )
        .FirstOrDefault();
      FilteredElementCollector intersectingInstances
        = new FilteredElementCollector( doc )
          .OfClass( typeof( FamilyInstance ) )
          .WherePasses( new ElementIntersectsSolidFilter(
            solid ) );
      int n1 = intersectingInstances.Count<Element>();
          .WherePasses( new ElementIntersectsElementFilter(
            e ) );
      int n = intersectingInstances.Count<Element>();
      Debug.Assert( n.Equals( n1 ),
        "expected solid intersection to equal element intersection" );
      string result = string.Format(
        "{0} family instance{1} intersect{2} the "
        + "selected element {3}{4}",
        n, Util.PluralSuffix( n ),
        ( 1 == n ? "s" : "" ),
        Util.ElementDescription( e ),
        Util.DotOrColon( n ) );
      string id_list = 0 == n
        ? string.Empty
        : string.Join( ", ",
              .Select<Element, string>(
                x => x.Id.IntegerValue.ToString() ) )
      Util.InfoMsg2( result, id_list );
    /// <summary>
    /// Retrieve all beam family instances
    /// intersecting two columns, cf.
    /// http://forums.autodesk.com/t5/revit-api/check-to-see-if-beam-exists/m-p/6223562
    /// </summary>
      GetBeamsIntersectingTwoColumns(
        Element column1,
        Element column2 )
      Document doc = column1.Document;
      if( column2.Document.GetHashCode() != doc.GetHashCode() )
        throw new ArgumentException(
          "Expected two columns from same document." );
      FilteredElementCollector intersectingStructuralFramingElements
          .OfCategory( BuiltInCategory.OST_StructuralFraming )
          .WherePasses( new ElementIntersectsElementFilter( column1 ) )
          .WherePasses( new ElementIntersectsElementFilter( column2 ) );
      int n = intersectingStructuralFramingElements.Count<Element>();
        "{0} structural framing family instance{1} "
        + "intersect{2} the two beams{3}",
        ? string.Empty
      return intersectingStructuralFramingElements;
    #endregion // Retrieve family instances intersecting BIM element
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Einar_Raknes
You can use the RebarHostData Class and the GetRebarsInHost Method to retrive all Rebars associated with a Rebar Host.
To make sure you pick a valid Rebar Host, you can create a selection filter: (optional step)
public class RebarHostSelectionFilter : ISelectionFilter
        public bool AllowElement(Element element)
            if (RebarHostData.GetRebarHostData(element) != null)
                return true;
            return false;
        public bool AllowReference(Reference refer, XYZ point)
            return false;
    } //class
And then pick a rebar host, and get a list of Rebars like this:
ref1 = uidoc.Selection.PickObject(ObjectType.Element, new RebarHostSelectionFilter(), "Pick a rebar host");
Element rebarHost = doc.GetElement(ref1)
IList<Rebar> rebarsInHost = RebarHostData.GetRebarHostData(rebarHost).GetRebarsInHost();
jeremytammik
Many thanks to Einar for jumping in and coming to the rescue!
Preserved for posterity by The Building Coder:
https://thebuildingcoder.typepad.com/blog/2018/12/rebars-in-host-net-framework-and-importance-of-fuz...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
