Incorrect Material Density
milindnalgirkar
milindnalgirkar
We applied floor material as "Plywood, Sheathing" and in Revit its shown the density = 34.46 pcf. as shown below snap:
and when we retrieve it through programmatically its getting density = 1.07 pcf. as shown in below code block snap:
Kindly suggest the API / Function that gets the correct value of density.
Thanks and regards,
Satwadhir.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @milindnalgirkar,
UnitWeight and Density are not same.
To get what you want try using the below code
string strdensity = UnitFormatUtils.Format(units, UnitType.UT_MassDensity, asset.Density, false, false);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
milindnalgirkar
Thanks for your quick reply.
