- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
These are my first lines in python working with the Revit API. I have looked for information in different forums and I cannot find the answer or I am not able to understand it.
I have made the following script that allows me to look up a value in a Built In Parameter.
# Test3
bip=BuiltInParameter.ALL_MODEL_MARK
provider=ParameterValueProvider(ElementId(bip))
evaluator=FilterStringEquals()
value="2"
rule=FilterStringRule(provider,evaluator,value,False)
filter=ElementParameterFilter(rule,True)
muros=FilteredElementCollector(doc).WhereElementIsNotElementType().WherePasses(filter).ToElementIds()
uidoc.Selection.SetElementIds(muros)
When I try to extrapolate the code to a shared parameter:
# Test4
lup=SharedParameterElement.Lookup(doc,Guid('7b587ac7-681e-4b97-9e56-94ea81b9bf47'))
provider=ParameterValueProvider(ElementId(lup))
value="aa"
The FilterRuleString provider shows the following error:
I understand that I should use another rule / filter but I have not found the correct way to do it. I have tried with: LookupParameter (), get_parameter (), GetParameters () to get the values and FilterStringEquals (prov, evaluator, value, False), ParameterFilterRuleFactory.CreateEqualsRule (prov, value, False) for rule creation without getting the desired result.
Thansk in advance.
