Require Open Source Addin-manager to fix error.
Chuong.Ho
Chuong.Ho
Hi guys,
I have a question, is Autodesk available open source addin-manager tool, so we can collaborate like Revitlookup. I have encountered some problems with the library quite often and need investigation to fix it. This is time-consuming when I am using a third-party library like devexpress or material design them.
I hope someone has a say in this matter ! Thanks you.
Chuong Ho
ricaun
I believe is not available, the last I asked the AddInManager was the close-source, and looks like Autodesk does not have the intention to open the project.
That's why I created my own plugin call ricaun.Console to fit my workflow, the plugin has a similar approach, load dll to run IExternalCommand without need to close Revit. I add a Console Pane to capture everything is written on the Console.WireLine and Debug.WriteLine, and some other interesting features like static variable works.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Chuong.Ho
Awesome. When I try with tool of you, it's working in my case, I'm wondering if Autodesk is not open source, don't know how long this problem will be fixed. Thanks for your tool.
Chuong Ho
